916Kev Posted September 12, 2008 Report Share Posted September 12, 2008 I have searched but haven't found anything similar to my problem. I have a 16gb iphone 3g and the f90bt. Basically the other night when I was navigating around my podcasts the unit restarted and continued to do so as long as the iphone was connected. I could disconnect my iphone and play a cd/fm radio and it works fine but when I plug the iphone back in the unit restarts over and over. This just started happening the other night. I reset the unit but that didn't help. Then I tried restarting the car but same deal. What can I do? Thanks. Quote Link to post Share on other sites
HiFiSi Posted September 12, 2008 Report Share Posted September 12, 2008 It's possible that the ipod cable may have gone bad? To check, just connect the ipod to the radio using the normal USB cable that came with the ipod. You won't get audio and video, but you will be able to use/control the ipod. If the radio keeps resetting after trying that, it's either the ipod or the radio that's causing the problem. Quote Link to post Share on other sites
916Kev Posted September 13, 2008 Author Report Share Posted September 13, 2008 I think the problem has to do with the latest iphone update (2.1) Quote Link to post Share on other sites
HiFiSi Posted September 13, 2008 Report Share Posted September 13, 2008 Well if that's true, I don't think there would be much you could do about it aside from rolling the firmware in the iphone back. Quote Link to post Share on other sites
skicrave Posted September 13, 2008 Report Share Posted September 13, 2008 I haven't had any problems with my 3G and 2.1 (yet). Knock on wood... Quote Link to post Share on other sites
