bikeme Posted September 5, 2006 Report Share Posted September 5, 2006 I need to locate the speed sensor and the reverse gear wire locations. Crutchfield can't find them. Type-S, Manual, Bose System too. Thanks Quote Link to post Share on other sites
ricerocket21x Posted September 5, 2006 Report Share Posted September 5, 2006 speed sense wire - blue/white at the ecm/pcm in a white plug behind the glove box or behind the instrument cluster at the speedometer plug reverse wire - green in the driver's kick panel, in the harness towards the rear Quote Link to post Share on other sites
richardlai414 Posted September 20, 2006 Report Share Posted September 20, 2006 [quote name="bikeme"]I need to locate the speed sensor and the reverse gear wire locations. Crutchfield can't find them. Type-S, Manual, Bose System too. Thanks[/quote] If you want your Bose to work right, you might want to get that wiring harness that has the RCA connectors on the speaker lead. Quote Link to post Share on other sites
cntrylvr79 Posted September 20, 2006 Report Share Posted September 20, 2006 You can't also get a regular honda harness p/n 70-1721, and a cheapo set of rca's. Cut the ends off the rcas about 6 or so inches long. Strip those and hook the center conductor up to the +speaker lead on the 1721 and the outer sheild to the negative speaker lead. Finally make sure you hook the remote lead from the avic up to the power antenna wire of the 1721. Instant bose interface. Quote Link to post Share on other sites
