bitman Posted September 22, 2008 Report Share Posted September 22, 2008 this is my hack i run on my f900bt at the moment. please be sure to know what you are doing as i don't take any responsibility if you brick your box. i will not put my data.zip file here since in my opinion it isn't a good idea to just copy a data.zip file on your box. i want to thank all on this board for directions, ideas & scripts. this hack puts the box in full cockpit screen mode by default and only shows those blue boxes when you navigate. the compass is a button to cancel your route. navigatemap_800_480.ui ; to use the compass button to cancel navigation route ; navigatemap_800_480.ui ; change the color of time printed on the screen ; variable_def.ui ;hack to remove blue bars and other unused stuff from screen while not navigating. this will put the navigation in full cockpit screen by default ; navigatemap.ui ; map.ZOOMCONTROL_SHOW 1 map.ZOOMCONTROL_SHOW 0 navigatemap_800_480.ui ; ; ; ; only needed if you want to keep secondary info on screen since this is disabled in fullscreen mode ; ; ; ; ; multi info box only on at navigation ; ; ; ; ; ; ; ; ; ; have fun, bt Quote Link to post Share on other sites
1fastrsx Posted September 23, 2008 Report Share Posted September 23, 2008 You are a God if this works.. I made all the changes.. will upload in the morning to see if it worked. Quote Link to post Share on other sites
bitman Posted September 23, 2008 Author Report Share Posted September 23, 2008 well i found a small bug. in the info box (bottom left) the speed and time is missing. so i need to fix that. otherwise it works fine. Quote Link to post Share on other sites
1fastrsx Posted September 23, 2008 Report Share Posted September 23, 2008 I noticed that also while driving in... thought I had messed something up. Quote Link to post Share on other sites
bitman Posted September 28, 2008 Author Report Share Posted September 28, 2008 sorry for the delay of coming back to this but i'm very busy on my work (worked 33 hours in one go this friday) so it will take me some (more) time to create a fix for this. Quote Link to post Share on other sites
