JeST Posted October 21, 2008 Report Share Posted October 21, 2008 My Z2 has been installed on the car for about 2 years now and as of recently the library cannot be heard. On screen it shows it playing but nothing is coming out of the speakers. AM/FM is working perfectly fine. Any help would be greatly appreciated. Thanks Quote Link to post Share on other sites
JeST Posted November 12, 2008 Author Report Share Posted November 12, 2008 help please Quote Link to post Share on other sites
CamelTowing Posted November 12, 2008 Report Share Posted November 12, 2008 Go into the initial/setup menu and change the Antenna Control setting to Power. If that works, you incorrectly tapped the power antenna wire instead of the remote turn on (system control) when you installed it Quote Link to post Share on other sites
JeST Posted November 14, 2008 Author Report Share Posted November 14, 2008 Go into the initial/setup menu and change the Antenna Control setting to Power. If that works, you incorrectly tapped the power antenna wire instead of the remote turn on (system control) when you installed it You my friend are a genius, either that or i'm an idiot. I believe it could be a mixture of both, lol. Thanks, that solved the problem. If you were closer I'd buy you a drink. Quote Link to post Share on other sites
CamelTowing Posted November 15, 2008 Report Share Posted November 15, 2008 Quote Link to post Share on other sites
