jml2008 Posted October 28, 2008 Report Share Posted October 28, 2008 In testmode I tried to open file folder to rename my data.zip file but can't get the screen to respond. I tried to calibrate my screen several times still can't open file folder. Anybody else have this problem, if so please advise. I can't do any modification at the moment. Also if someone knows a workaround. Quote Link to post Share on other sites
lava10t2 Posted October 28, 2008 Report Share Posted October 28, 2008 clicking on start work? what happens after the trasnfer window closes, or are you even able to close it? Quote Link to post Share on other sites
jml2008 Posted October 28, 2008 Author Report Share Posted October 28, 2008 I can get in and out of testmode no problem, right corner,bottom right and left coreners work ok, only top left corner were that file folder is, the most important one. Quote Link to post Share on other sites
lava10t2 Posted October 28, 2008 Report Share Posted October 28, 2008 did you screen calibrate inside of WinCE or inside of Avic? Try each of them and see if it helps. Also, i know it's stupid, but you're using the stylus correct? Quote Link to post Share on other sites
jml2008 Posted October 28, 2008 Author Report Share Posted October 28, 2008 yes inside wince and avic with stylus. The edit,view etc are ok, only file giving me problems. Quote Link to post Share on other sites
skicrave Posted October 28, 2008 Report Share Posted October 28, 2008 Start -> Windows Explorer will bring up a new Explorer window. Quote Link to post Share on other sites
bbotzong Posted October 29, 2008 Report Share Posted October 29, 2008 I had to first run the screen calibration. Then I had to figure out you have to tap each icon three or four times to get a 'double click'. If you tap it only twice, it doesn't respond. Try tapping multiple times. Quote Link to post Share on other sites
jml2008 Posted October 29, 2008 Author Report Share Posted October 29, 2008 tried all that now seems like my edit and file folder won't came up when tap on them. Can't get a modyfing my files. can the window be moved around the creen so maybe I can use the file and edit functions. Quote Link to post Share on other sites
jml2008 Posted October 30, 2008 Author Report Share Posted October 30, 2008 Thanks guys for your help but I found a roundabout way to get to the file by recalebrating the screen to be off abit on the top left side. Quote Link to post Share on other sites
