firedogrod Posted December 18, 2008 Report Share Posted December 18, 2008 i am running the 2.2.x firmware on my itouch and 2.0 on the f900bt. using just the usb and the A/V usb cable the ipod doesnt recognize that anything is plugged in. is there any one else that is in the same predicament and possibly have a work around Quote Link to post Share on other sites
carlsbad0331 Posted December 18, 2008 Report Share Posted December 18, 2008 Vary rarely, I have the Ipod not recognized. I simply unplug it and plug it back in while the radio is on and it becomes recognized. Also, just to be clear... you need to select the ipod as the AV1 selection.If neither of these are the issue, maybe a bad cable??? PS: I am running the 32gb Itouch with the same firmware on the ipod and the AVIC. Quote Link to post Share on other sites
e39m5 Posted December 18, 2008 Report Share Posted December 18, 2008 Same problem, ugh. My iPod Nano works fine, but it doesn't even recognize I plugged in an ipod when I hook up the Touch. It just shows USB greyed out, but it appears to charge my ipod. I've searched and don't see a solution, who should I contact? Pioneer? e39m5 Quote Link to post Share on other sites
firedogrod Posted December 18, 2008 Author Report Share Posted December 18, 2008 i have AV1 changed to ipod and nothing happens. i get audio through AV1 only when it is changed to video. i also have a dehp6000ub and it works with that radio like a champ. but for some reason i cant get the f900's ipod interface to pull up. Quote Link to post Share on other sites
madsonp Posted December 18, 2008 Report Share Posted December 18, 2008 Try resetting the unit Quote Link to post Share on other sites
dan2010 Posted December 18, 2008 Report Share Posted December 18, 2008 Reseting the ipod has worked for me Quote Link to post Share on other sites
e39m5 Posted December 20, 2008 Report Share Posted December 20, 2008 What do you mean by resetting the ipod? And resetting the unit? e39m5 Quote Link to post Share on other sites
e39m5 Posted December 21, 2008 Report Share Posted December 21, 2008 This is really pissing me off, I can't get my iPod touch to work. Who should I contact? This is a main feature of the system, and it's not working. e39m5 Quote Link to post Share on other sites
madsonp Posted December 21, 2008 Report Share Posted December 21, 2008 Push the reset button on the head unit Quote Link to post Share on other sites
e39m5 Posted December 23, 2008 Report Share Posted December 23, 2008 Nothing...Does anyone have this working with their first gen iPod Touch? I spent nearly $1000 on this install and as far as I can tell there's no reason this shouldn't be working. e39m5 Quote Link to post Share on other sites
cranbers Posted December 23, 2008 Report Share Posted December 23, 2008 Have you tried a different usb cable? have you tried resetting the unit, via the tiny button by the eject? Have you tried turning the ipod touch off, that is holding the black side button the top till it says slide ot turn off, let it turn off, then turn it back on. If it still doesn't recognize it, try another ipod, if that works, then you know its not the unit, if it doesn't work and you tried another cable, you know something is wrong with the unit. Just to rule out a problem with the usb cable on the unit (not the ipod adaptor cable) try plugging a thumb drive into it with music on it. If the unit recognizes it, then you know the usb is working fine, if that doesn't work then you know the main usb cable is bad. (not the ipod adaptor cable that plugs into it. I am sure we would of heard a lot more complaints about ipod touch not working, it had major issues prior to the 2.0 update. It never worked before correct? So all you can do is rule out what's wrong, the ipod cable, the ipod touch or the unit itself. Try the apple a/v composite cable, available at any electronics store and even walmart. Quote Link to post Share on other sites
