bwolfe Posted December 23, 2008 Report Share Posted December 23, 2008 I know there are discussions mixed in other topics but I find it difficult to dig to find bits and pieces of information, so I decided to create a topic. I am trying to get the GARMIN MOBILE XT to work with LEETLAUNCHER. I must be doing something wrong or missing a step that is embedded in all the other topics. How do you get it working? I have the GARMIN MOBILE XT MAPS and when I follow the directions on the torrent it makes it all messed up and dumps a bunch of folders on my SD card and such. So has anyone got this working that can post some step by step instructions that are easy to follow and complete? Thanks Quote Link to post Share on other sites
bwolfe Posted December 23, 2008 Author Report Share Posted December 23, 2008 Has anyone got this to work right, that can help? Quote Link to post Share on other sites
alien2000a Posted December 23, 2008 Report Share Posted December 23, 2008 Well I know how to get garmin installed and get it working on windows mobile 6 with maps and stuff but don't know how to do it on CE. Quote Link to post Share on other sites
jml2008 Posted December 26, 2008 Report Share Posted December 26, 2008 I keep lossing my GPS signal on Garmin XT as soon I drive for a few seconds, been asking around still no solution. Does member have a solution? Quote Link to post Share on other sites
bwolfe Posted January 1, 2009 Author Report Share Posted January 1, 2009 *BUMP* Anyone? Anyone? Beuller? Quote Link to post Share on other sites
yoav Posted January 1, 2009 Report Share Posted January 1, 2009 Can't answer about the gps signal loss (I don't use the garmin XT), but if you want to get it to work, there are a few steps: 1) start the program. Tell it to connect to a Garmin GPS, then have it fail (click skip or whatnot). Then it will run without a GPS signal. You need to go to the settings... About, and write down the device ID (it's a 10-digit number thing). Bring the SD card back to your computer... 2) Head back to your computer. You will need to find an appropriate map (do the usual search -- I'm not posting anything like that here). You will also need to get yourself a copy of "Garmin Unlock Generator" (same sort of place will have it). Every map has a map code (a three-digit code), or is a fully unlocked map. 3) Run the key generator. Select Garmin XT. Give it your device ID, and it will generate a long unlock string. Copy that string down into a file named 'SW.UNL' in your Garmin folder on the SD card. 4) Copy the map to the Garmin directory. Generate a key to unlock said map, and put that in a file named gmapsupp.unl (should match the map file whose name is something like gmapsupp.img??). That should get you past the unlocking... As for the other problems with the Garmin code, someone else will have to help you... Quote Link to post Share on other sites
bwolfe Posted January 1, 2009 Author Report Share Posted January 1, 2009 Thanks for pointing me the right direction. Quote Link to post Share on other sites
