Big Top Gt Posted January 4, 2009 Report Share Posted January 4, 2009 I just finished looking at the searchable threads and came up with nothing, so here I am. I've got an 05 Mustang that had a Shaker 500 sound system in it. The car now has a Z1 in it with the factory 8" subs and 5x8's in the door, along with Kicker 5x8's in the rear deck. I just picked up a shaker 1000 sub setup, along with the amps, and I'm curious as to what it'll take to hook these up. If anyone has some information or a source for the wiring I need to work out, I'd like to hook them up asap. Thanks in advance and happy new year. Alan Quote Link to post Share on other sites
1PACMAN Posted January 16, 2009 Report Share Posted January 16, 2009 You shouldnt have wasted your money on the Shaker 1000 subs.They are a waste of money.I pulled mine out. You will get more bass from your system if you put your door subs on a better amp.My door subs hit harder then the 10 in the trunk. Check for the wiring in the right corner of your trunk. Quote Link to post Share on other sites
st577 Posted January 25, 2009 Report Share Posted January 25, 2009 you need to get an inline converter it is installed inline with your rear speakers and will not rob them of any power, the other end has RCA jacks to be plugged into the input of the amp for the rear subs. I had one with my shaker 500with a 600watt jbl amp & two 10" Jbl subs one ported and one not. The sounded great. Now I have the z3 and have the subs run right from the rca out from the reciever, that way I can control the level and frequency also a great sounding setup. You can get an inline converter from any car stereo shop or Best Buy. Quote Link to post Share on other sites
st577 Posted January 25, 2009 Report Share Posted January 25, 2009 Here it is PAC Adjustable output adaptor Model SNI-35 simple set up the shop may rape you for 75 bucks or so I've seen them for more I think they are worth about 10bucks check out ebay! Quote Link to post Share on other sites
1PACMAN Posted January 26, 2009 Report Share Posted January 26, 2009 Your best bet is to use this part to add an amp. This is a plug and playconverter for the Fords. P/N AOEM-FRD24. I have it on my Shaker 1000 added a 12" Orion sub in the spare tire well and removed the fatory 10's. Quote Link to post Share on other sites
