blind1595 Posted September 27, 2006 Report Share Posted September 27, 2006 Okay, well, I had my installer put in the DB Circuit and hook-up the ILL Wire for the illumination to work in my 06 Mustang, but... One problem. I occasionally will get that Parking Break Incorrectly Installed Message, and I am not sure if it is because (I am guessing) the parking break was grounded or for whatever other reason. If I reset the unit, it will work for a while without giving me that warning message, but eventually it will come back. Its pretty sporadic. Anyone had a similar experience or problem like that? Would appreciate any info on how to fix that problem. Thanks. Quote Link to post Share on other sites
matthieuallie Posted September 27, 2006 Report Share Posted September 27, 2006 just posted a similar one... The reason i think is that you parking brake wire is grounded, so when vehicle is moving the systems sees the barking brake on while vehicle is in motion which does not make sens so it sends the Warning. Same for me, when I reset the unit, Warning goes away but eventually comes back... You have to leave the parking brake wire disconnected (just tape it off). BTW, i think the manual light flashing and/or the DB circuit will not work if the parking brake wire is permanently grounded. I have to go back to my shop to ask them to disconnect it from the ground... Quote Link to post Share on other sites
ducatiboy Posted September 27, 2006 Report Share Posted September 27, 2006 Yah, if you install my circuit, you don't want to ground the parking brake wire. Unhook that from ground, and then reset the Z1 and you will be good to go. You won't get that message any more and everything will work all the time... for 3 minutes or many hours.... Quote Link to post Share on other sites
