sjwaste Posted January 19, 2009 Report Share Posted January 19, 2009 Would the original iPOD USB cable that came with the iPOD work? I see that Pioneer cable has RCA leads as well as USB connector. If the stock iPOD cable works with the USB connection, why do we need RCA leads? You need the composite cable with the RCA jacks, the AVIC uses USB to control the ipod, but the audio and video inputs are handled via the RCA inputs, not the USB. Wait, so if I use the stock Pioneer ipod cable, I have to hook up the dock connector on the bottom AND something off of the headphone jack to get it to play? Or will it use the dock connector for everything if I use the Pioneer cable? Quote Link to post Share on other sites
dianebrat Posted January 19, 2009 Report Share Posted January 19, 2009 Wait, so if I use the stock Pioneer ipod cable, I have to hook up the dock connector on the bottom AND something off of the headphone jack to get it to play? Or will it use the dock connector for everything if I use the Pioneer cable? the "dock connector" also carries audio and video outputs, it's all that you need to connect as long as you use the correct ipod cable with RCA's Quote Link to post Share on other sites
