2fasst Posted January 12, 2009 Report Share Posted January 12, 2009 I understand about moving the yellow/black wire from Pin 1 to Pin 2. I also understand that this wire needs to be connected to the Light Green Parking Brake wire on the other harness. Then these two wires need to be grounded. My question is according to the manual the Light Green Parking Brake wire 'Should have' been connected to the POSITIVE side of the Parking Brake switch. So am I understanding it right that to 'hack/bypass' this I should now connect this Light Green Parking Brake wire to GROUND along with the Mute Yellow/Black wire??? Please confirm guys before I short/burn something Quote Link to post Share on other sites
andrios Posted January 12, 2009 Report Share Posted January 12, 2009 yup you got it! Quote Link to post Share on other sites
2fasst Posted January 12, 2009 Author Report Share Posted January 12, 2009 thanks! i appreciate it! Quote Link to post Share on other sites
dianebrat Posted January 12, 2009 Report Share Posted January 12, 2009 If you look at the diagram on the install sheet you'll see why grounding it is ok.. All the parking switch does is bring the signal line down to ground when the switch is closed. Quote Link to post Share on other sites
