DrBass Posted February 7, 2009 Report Share Posted February 7, 2009 We've installed quite a few 700's and 900's and have done the software speed bypass with no issues. I have one customer that is complaining that the parking brake warning is randomly popping up on the screen. Its a 900BT Is this normal after the software bypass, and no one else has complained about it, or is something potentially wrong? I've searched the forum and couldn't find anything about it. Thanks Mike Quote Link to post Share on other sites
drycutu Posted February 7, 2009 Report Share Posted February 7, 2009 I would check and make sure the brake wire is grounded and make sure u copyed the modified data.zip not the original, i did that the first time, also try 256.0 for the value for the parking brake, that worked for me Quote Link to post Share on other sites
S4 Posted February 7, 2009 Report Share Posted February 7, 2009 i doubt its software that is causing it. the software either works or it doesnt. check wiring and grounding. while the unit is running wiggle wires around and see if you replicate the problem. Quote Link to post Share on other sites
paQ Posted February 7, 2009 Report Share Posted February 7, 2009 I have that with only the hardware bypass. (and not having it to work) I added the software bypass, and the error has gone. (and it works now) Quote Link to post Share on other sites
dianebrat Posted February 7, 2009 Report Share Posted February 7, 2009 I have that with only the hardware bypass.(and not having it to work) I added the software bypass, and the error has gone. (and it works now) If you get the parking brake warning with the hardware bypass, then it's simple, you did not do it correctly. Quote Link to post Share on other sites
paQ Posted February 7, 2009 Report Share Posted February 7, 2009 I have that with only the hardware bypass.(and not having it to work) I added the software bypass, and the error has gone. (and it works now) If you get the parking brake warning with the hardware bypass, then it's simple, you did not do it correctly. checked it a dozen times... even measured the leads, but no succes Quote Link to post Share on other sites
Hover-Shuttle Posted February 8, 2009 Report Share Posted February 8, 2009 I have one customer that is complaining that the parking brake warning is randomly popping up on the screen. Its a 900BT DrBass, I did the software bypass on my '900BT... I changed it to "128"... when I hit 79.5 mph I get the "Park Brake is Incorrectly Connected" Warning every time. Just change the setting to a higher number eg. 256 (it should be good up to 159 mph?), or tell them not to speed! Hover-Shuttle Quote Link to post Share on other sites
viper62 Posted February 8, 2009 Report Share Posted February 8, 2009 I had to change mine to 256. Has the previous post said, you will get this error if you set the software bypass to 128 and you go over 79mph. The speed setting is in kph not mph. Quote Link to post Share on other sites
S4 Posted February 8, 2009 Report Share Posted February 8, 2009 ooops, I missread the first post. I thought you did both software and hardware. Quote Link to post Share on other sites
pyrofallout Posted February 12, 2009 Report Share Posted February 12, 2009 I had to change mine to 256. Has the previous post said, you will get this error if you set the software bypass to 128 and you go over 79mph. The speed setting is in kph not mph. bingo! i just noticed this the other day on the freeway. i just changed mine to 256. Quote Link to post Share on other sites
jeep_owner Posted February 12, 2009 Report Share Posted February 12, 2009 I have one customer that is complaining that the parking brake warning is randomly popping up on the screen. Its a 900BT DrBass, I did the software bypass on my '900BT... I changed it to "128"... when I hit 79.5 mph I get the "Park Brake is Incorrectly Connected" Warning every time. Just change the setting to a higher number eg. 256 (it should be good up to 159 mph?), or tell them not to speed! Hover-Shuttle Thanks for this info...I to have this message popping up at 80mph. Guess I'll be upping it to 256 Quote Link to post Share on other sites
