donmeca2020 Posted February 14, 2009 Report Share Posted February 14, 2009 this might have been adderessed before but how would i go about cleaning the screen? lcd cleaner? or any other method? its about due to get cleaned Quote Link to post Share on other sites
S4 Posted February 14, 2009 Report Share Posted February 14, 2009 I'm sure this is going to get wide range of answers but for me the best and non destructive way is to use damp microfiber towel and gently clean the screen and while it's still wet use a dry one to dry the screen. Since you are not cleaning the actual LCD but rather touchscreen glass I don't think you can do much damage but if you do use products with alcohol it might permanently streak it. I've seen people do this on our old $25K imaging monitors Quote Link to post Share on other sites
donmeca2020 Posted February 14, 2009 Author Report Share Posted February 14, 2009 hmm well what is the way pioneer recommends cleaning it ? Quote Link to post Share on other sites
skicrave Posted February 14, 2009 Report Share Posted February 14, 2009 Use a non-abrasive, non-caustic cleaner to lightly dampen applied to a 100% or microfiber towel. The only thing that will do damage is an abrasive cleaner or towel that will scratch the surface, a caustic cleaner that will discolor, or too much moisture which will damage the electronics. I typically use water, which is plenty to remove fingerprints and oils from the screen. Quote Link to post Share on other sites
spta97 Posted February 18, 2009 Report Share Posted February 18, 2009 I typically use Invisible glass to clean screens (laptops, TVs) with a microfibler cloth. It does not contain ammonia and is much safter than Windex or Glass Plus. It is also the best glass cleaner you will ever use! You can buy it at Wal-Mart, Lowes, and auto parts stores: http://www.invisibleglass.com/ Quote Link to post Share on other sites
S4 Posted February 18, 2009 Report Share Posted February 18, 2009 I don't know if I would use Invisible Glass on my LCD's but I love that stuff and use it on the car to clean anything. Quote Link to post Share on other sites
syb0rz Posted February 18, 2009 Report Share Posted February 18, 2009 50% rubbing alcohol 50% water Manufactures usually recommend this for any LCD screen. Quote Link to post Share on other sites
spta97 Posted February 18, 2009 Report Share Posted February 18, 2009 I don't know if I would use Invisible Glass on my LCD's but I love that stuff and use it on the car to clean anything. Surely it is less harsh than alcohol? Quote Link to post Share on other sites
S4 Posted February 18, 2009 Report Share Posted February 18, 2009 I don't know if I would use Invisible Glass on my LCD's but I love that stuff and use it on the car to clean anything. Surely it is less harsh than alcohol? I didn't say I would use alcohol ... EVER I'd rather use IG than any other cleaning solution, manufacturer "approved" or not. Clean warm water is all I would use. Quote Link to post Share on other sites
jerros Posted February 20, 2009 Report Share Posted February 20, 2009 You can find all sorts of products to clean your screen. I would however NEVER use any type of glass cleaner (Even invisible glass). If your trying to clean off dust on the screen than a damp microfiber cloth should do the trick. Then dry it with another microfiber cloth that's dry. If your screens got alot of oily fingerprints/soda sputters then you'll want to buy a little bottle of LCD screen cleaner (you can pick this up in staples, office depot, best buy, in the laptop section or for a bigger bottle of the stuff check the LCD TV sections of your local tv retailer), and bust out the microfiber cloth I talked about before. (http://www.klearscreen.com/SearchResult ... egoryID=53 is an example). The whole idea behind the cleaning liquid is to provide some sort of cleaning solution to the screen which will allow for the removal of any spots/stains with out you applying too much pressure and causing the LCD screen to rupture and bleed into other nearby areas. You want to make sure the cleaner you buy is alchol & amonia free or it could damage the screen either immediately or over time (depending on the alchol/amonia ratio in the product). Using a damp microfiber cloth (damp with warm water) can typically remove most of the dirt and grime from a screen like this, but on rare occasions (if your avic is near a cup holder for instance) you might need the cleaner to remove something thats a little more difficult to get out. Quote Link to post Share on other sites
donmeca2020 Posted February 20, 2009 Author Report Share Posted February 20, 2009 thanks guys, yea i have the usual finger spots and other lil speckles cant figure out from what so i might go get a small bottle of that LCD cleaner Quote Link to post Share on other sites
