brian_moreau7 Posted February 21, 2009 Report Share Posted February 21, 2009 Hello........I have an Avic D3 Installed in a 2005 Chevrolet Silverado With The Bose Stereo And Onstar.... I Used the Peripheral(Stinger) GMAH24B Adapter To wire in the deck, Works Great!! I installed the deck about 6 months ago...... I have done alot of car audio installs but this one has me stumped......... The Problem I am Having is every so often while I am driving the deck turns off and then powers back up almost instantly, When it does this it resumes back to what i was doing, It seems to be doing it more frequently now so i pulled the deck back out and checked all connections they all seem to be good, I pulled and wiggled on every wire hooked to the unit and could not make it turn off and on like it does while driving. Everything is wired using The factory wiring harness so should have great ground and good 12v... Also i have the deck bypassed could that be the problem? Any ideas of what is wrong?? Bad Ground?, Bad+12v, Solutions? Thanks!!!!! Quote Link to post Share on other sites
vingavina Posted February 25, 2009 Report Share Posted February 25, 2009 i have the same problem.. any help would be appreciated.. Quote Link to post Share on other sites
thomashohl Posted February 28, 2009 Report Share Posted February 28, 2009 Well, this sounds very similar to my problem. I have a D3 in a 2006 Silverado and it drains the battery after about 5 days. The unit is causing a 2 amp draw. I have no idea what the hell is going on but it has taken 2 months of removing and replacing fuses and a trip to GM to find the problem. I have a D3 in my 2008 Toyota as well and no problems. I have been thinking about hitting the reset button on the back of the unit and trying that. Anyone else experiencing this? Quote Link to post Share on other sites
cafagna Posted March 1, 2009 Report Share Posted March 1, 2009 I have narrowed it down to either it being too cold at the startup or the upgrade DVD. Those are the only things that have been changed. I too ripped the radio back out and tightened all wires, etc. I checked and there is no 2AMP draw from mine. I really am confused by the problem as I have had the radio for two years and it is just starting with this nonsense now. Quote Link to post Share on other sites
vingavina Posted March 3, 2009 Report Share Posted March 3, 2009 I have narrowed it down to either it being too cold at the startup or the upgrade DVD. Those are the only things that have been changed. I too ripped the radio back out and tightened all wires, etc. I checked and there is no 2AMP draw from mine. I really am confused by the problem as I have had the radio for two years and it is just starting with this nonsense now. i really think my problem is the upgrade disc.. Quote Link to post Share on other sites
DSMKilla Posted March 5, 2009 Report Share Posted March 5, 2009 I had this same problem one time and it ended up being a shitty connection in the stock BCM harness. Was this happening with your stock deck? How long have you had the truck? Quote Link to post Share on other sites
brian_moreau7 Posted March 6, 2009 Author Report Share Posted March 6, 2009 I Have had the Truck since new (2005) Never had any problems with the stock deck, Mine does not have any current drain.... DSMKilla you mentioned it was a bad connection in the BSM Harness any ideas as to what wire was bad? .................... Also upgraded unit with new Pioneer CDMV-80mt Realese this did not solve the problem... Quote Link to post Share on other sites
brian_moreau7 Posted January 28, 2010 Author Report Share Posted January 28, 2010 TTT Quote Link to post Share on other sites
