Esteb Posted February 27, 2009 Report Share Posted February 27, 2009 It all started since I installed the LeetLuncher to test it, on wednesday, something happened at that time (I think). The next day I found maps of Argentina, my country (my friend GUGA really found them..thanx GUGA!!), so I decided to load them on my AVIC. So I started in testmode, I went to \APL2\iGo and I noticed that it didn't have the same files and folders than other (like you). I have in another place: \My Flash Disk\User\SystemData\InitComm\ here're all files & folders, including EZRider.exe, licences, data.zip, bla bla bla (look at the pic below). Anyway, I copied the hacked iGo folder (downloaded from some popular topic here) in its corresponding place (\APL2\iGo), took his time, and then I put all de map data in there. Fine, here start the trouble. Then I explore \My flash disk\ and I found that files were not where they should be, everything was unstructured, with the peculiarity that the folder \APL2\iGo containing infinite \iGo folders (take a look to the 3th pic). "\My Flash Disk\APL2\iGo\APL2\iGo\APL2\iGo\APL2\iGo\APL2\iGo\APL2\iGo\APL2\iGo............" The worst thing is that will not let me delete, copy or move files or folders, nothing, not even format the memory. What happened? How do I restore my flash disk? (I have the 2 gb memory and image of the F90bt US downloaded from de FTP site) This happened to someone else? Please help me!! This is what I have: AVIC F900-BT with US & Canada maps. Firmware 2.0 (updated about 1 month). Crashed, yesterday...jejeje!! Thanx a lot!! I hope some good news PS: Sorry my english UPDATE!! PROBLEM FIXED!! 16/mar/2009 Hi everyone!! I fixed my problem. So I'll go to explain, step by step, to help others having the same problem. I'll begin by the end, I could fix it by formatting the memory normally (after dismounting). The problem was that I could not do that (read the original post) As I wrote above, I had a loop in APL2/iGo folder, which used space in My Flash Disk and not allowed to me to copy new files (maps, data.zip, licenses, etc). I've tried many ways to break the loop, but without success. So I decided to look for Win CE software that could do it for me, but, to my bad luck, none worked. So, in the end, after trying a lot, I decided to try dismount the memory again (Part00* of the memory NAND with 1.8gb of space named "My Flash Disk") and then format it. First I tried with the USB pen driver connected to the unit, and it worked!!! So then I tried with the memory and it worked too!!! I don't know how, but it does. Definitly, I don't know what could cause this problem?? I suppose that some active process of the system that not allowed to copy, move or delete files even format the memory. Apparently at some point the process stopped and I was able to do so. When? I don't know?? ...well, thanx to everyone here in this forum!! I took a little of each post. For more details, just ask me. Quote Link to post Share on other sites
Esteb Posted February 28, 2009 Author Report Share Posted February 28, 2009 Nobody?? Quote Link to post Share on other sites
texbar24 Posted March 7, 2009 Report Share Posted March 7, 2009 I'm having almost this same problem! I removed my key beeps and now a fatal error about some ezrider file won't let the syatem finish the startup. Did you ever find a fix for yours? Quote Link to post Share on other sites
another gsxr 1k Posted March 7, 2009 Report Share Posted March 7, 2009 He's going to need to format the flash disk and replace everything from the looks of things. Texbar, PM me your email address and I'll give you access to my files so you can replace the ones you modded with my copy of the original file. Quote Link to post Share on other sites
Esteb Posted March 7, 2009 Author Report Share Posted March 7, 2009 Hi, I have some progress, but I´m not sure about your problem, do you can´t delete files (or rename, or move, or copy/paste), or your ezrider.exe?? Quote Link to post Share on other sites
Esteb Posted March 7, 2009 Author Report Share Posted March 7, 2009 My problem is that I can't format my flash disk, does't allow me. Somebody had this problem before? Quote Link to post Share on other sites
texbar24 Posted March 7, 2009 Report Share Posted March 7, 2009 I found my fix!! Erase the files under the Saved files folder. Had to reset all my setting but it worked! Quote Link to post Share on other sites
kvardar Posted March 9, 2009 Report Share Posted March 9, 2009 hi, how can I entering test mode? Quote Link to post Share on other sites
loy Posted March 10, 2009 Report Share Posted March 10, 2009 http://www.avic411.com/forum/viewtopic.php?t=17542 Quote Link to post Share on other sites
vreesb Posted September 23, 2010 Report Share Posted September 23, 2010 Hello, I comming from holland and i have allmost the same problem. I could not remove the APL2 folder from my flash card when i click remove an error comes with " cannot read from the source file or disk ". What can i do about it?? Please Help me regards Bert Quote Link to post Share on other sites
