08LaRam Posted March 21, 2009 Report Share Posted March 21, 2009 I have an 08 Dodge 1500 with the factory sirius antenna. Can I make this work with my Avic Z1(w/Z3 update) using an XM adapter/interface. If so, how? The XM is currently working fine with the little stick-on antenna (mounted on my dash) but I would really like to be able to make use of the Sirius antenna on the roof of my truck. Quote Link to post Share on other sites
08LaRam Posted March 29, 2009 Author Report Share Posted March 29, 2009 I guess from the response or lack there of there is no way to do this Quote Link to post Share on other sites
garrettoomey Posted March 29, 2009 Report Share Posted March 29, 2009 I am using the stock Sirius antenna from my 07 Dodge Ram with teh Pionner XM nav traffic unit. I had to remove the plastic housing from the stock antenna wire so that it would fit. Quote Link to post Share on other sites
08LaRam Posted March 31, 2009 Author Report Share Posted March 31, 2009 I am using the stock Sirius antenna from my 07 Dodge Ram with teh Pionner XM nav traffic unit. I had to remove the plastic housing from the stock antenna wire so that it would fit. Thanks, although I am not using nav traffic adapter I will see if that will work on my Pioneer XM adapter. Quote Link to post Share on other sites
1loudls Posted March 31, 2009 Report Share Posted March 31, 2009 you will need to find where the factory sirius module goes and put your xm module in its place, also a lot of the time the connector is very similar but not 100% the same so you will need to remove the plastic connector to plug it in Quote Link to post Share on other sites
1loudls Posted March 31, 2009 Report Share Posted March 31, 2009 or you can use a 50' home ant extension to put the module where ever you want it Quote Link to post Share on other sites
garrettoomey Posted March 31, 2009 Report Share Posted March 31, 2009 The factory sirius unit is behind the glove box on the Dodge Ram. Quote Link to post Share on other sites
