Turbaru Posted April 7, 2009 Report Share Posted April 7, 2009 Hey all! I am installing an F700BT with HD tuner module. I hooked the antenna into the HD module and I only get HD radio, no FM or AM. Do I need to install an antenna splitter and hook up the AVIC as well? thanks alot for the help! Quote Link to post Share on other sites
rareform Posted April 7, 2009 Report Share Posted April 7, 2009 Hey all! I am installing an F700BT with HD tuner module. I hooked the antenna into the HD module and I only get HD radio, no FM or AM. Do I need to install an antenna splitter and hook up the AVIC as well? thanks alot for the help! Read the manual, the HD tuner can get AM/FM and HD. You can use a splitter, I do, just so all icons on the menu actually work. Quote Link to post Share on other sites
Turbaru Posted April 7, 2009 Author Report Share Posted April 7, 2009 I read the manual and read that it is capable of all three but I am only getting HD radio, no AM or FM. That's why I figured I would ask the pros. Thanks for responding. Quote Link to post Share on other sites
Egz Posted April 7, 2009 Report Share Posted April 7, 2009 I read the manual and read that it is capable of all three but I am only getting HD radio, no AM or FM. That's why I figured I would ask the pros. Thanks for responding. I'm having the same issue as well. Seems like I lost almost everything. I haven't started troubleshooting it yet, so for me, it could very well be a bad antenna connection. Is there by rare chance a store that sells a splitter? Or am I going to have to make my own? Quote Link to post Share on other sites
1loudls Posted April 7, 2009 Report Share Posted April 7, 2009 the HD Radio is your AM and FM, if you want all three icons to work then yes you need to use a splitter, welcome to the wonderful world of HD Radio XM FTW Quote Link to post Share on other sites
Egz Posted April 9, 2009 Report Share Posted April 9, 2009 Well, I solved my issue. Ended up the antenna wasn't making a good enough contact with the HD tuner. I had to pry out the sides of the plug a little to make it a better fit. Too bad that didnt solve my issue of bad stations in the area... Quote Link to post Share on other sites
dianebrat Posted April 9, 2009 Report Share Posted April 9, 2009 Well, I solved my issue. Ended up the antenna wasn't making a good enough contact with the HD tuner. I had to pry out the sides of the plug a little to make it a better fit. Too bad that didnt solve my issue of bad stations in the area... Everything I've read says that you want to use a splitter and use the internal AM and FM not the ones in the HD Tuner since it's LESS sensitive and provides poorer non HD reception then the originals. Quote Link to post Share on other sites
