Agent4834 Posted May 2, 2009 Report Share Posted May 2, 2009 I know that there would have to be a way to get the 700 to read a divx or xvid file. has anyone found out how to do this? Quote Link to post Share on other sites
jdoggraz Posted May 2, 2009 Report Share Posted May 2, 2009 You can play videos on f700 through using the SD card. Quote Link to post Share on other sites
side0ut Posted May 5, 2009 Report Share Posted May 5, 2009 I can play divx on both sd and usb. xvid will play but the video will be very choppy. I always have to encode my xvid to divx to play properly. Also, I found that the frame rate should be about 700. I found that the video gets choppy past 800. I also usually select at least 640 for resolution so that I can get full screen. Quote Link to post Share on other sites
mrchrisbrown Posted May 7, 2009 Report Share Posted May 7, 2009 how about the f 90. i cant get it to work off of a disc Quote Link to post Share on other sites
apexi350z Posted May 11, 2009 Report Share Posted May 11, 2009 I can play DivX on F700bt from SD card (16GB) , but the ff and rew doesn't work.. Does it work for you guys? Quote Link to post Share on other sites
