help a n00bie: Stuck on Testmode.zip!
Hi guys, am new to this forum and hacking my F700BT (Euro version). Only had it a couple of weeks but keen to mod it because of the amount of deficiencies in the software! But that's another story you've all heard several times before...
My issue at the moment is step 1 - getting into testmode! I've downloaded the file from here: http://avic411.com/forum/viewtopic.php?f=34&t=18977
Extracted MiTACAP and Testmode folders to the root of a formatted SD card (tried several - a 1Gb, 2Gb and 2x 4Gb SDHCs - all with the same result, see below. The unit has been updated to the latest firmware and BT versions).
Testmode - Results
1. OK, so with the engine off / unit off I put the SD card into the unit.
2. Switch on ignition. Splash screen appears.
3. After about 15-20 seconds a window appears saying:
Error
MapDBinfo: 0x1000 < = > Device: 0x0010
AU: 0x0001
EW: 0x0010
RE: 0x0100
UC: 0x1000
Sounds like my DB doesn't expect the map version I have?!
Anyway, whatever the cause, I can't get into WinCE and don't know how to correct the error! What am I doing wrong???
Any help would be appreciated...
Open MiTACAP folder on SDCard, go into APL2 > iGO > content > MapDBInfo, and change the 'Area' code to your particular region:
AU: Australia
EW: Europe
RE: Asia (I think)
UC: USA/Canada
Should be good to go :wink:
EDIT: your device is Europe, so change UC to EW
That worked a treat. Got in to WinCE no probs.
Just for my general education, because I've read loads of threads and still not clear, after downloading a mod do I just copy that mod to my SD card (the one with the testmode boot on it) and then copy the individual modded files over, or do I update my backed-up MyFlashDrive on the SD and copy that back?
Sorry for appearing dumb. I promise I'll only need to be told once!
Can wait to improve this unit...
