mixhard Posted May 13, 2009 Report Share Posted May 13, 2009 I have the VSS wire hooked up to the blue white at the cruise control module just above the gas pedal. and i chose the speed to display on the route info window on the map screen. I still just have an exclamation mark there and it shows 0km/h. I have had the unit installed for about a week without it hooked up so i tried resetting the unit to see if it needed that to recognize that the VSS was hooked up. And still no dice. Any ideas where i've gone wrong?.... i know im on the right wire at the cruise module as i have verified the pin location with mitchell ondemand. Thanks in advance!!! David Quote Link to post Share on other sites
mixhard Posted May 13, 2009 Author Report Share Posted May 13, 2009 seems to be working fine, but it doesnt seem to show speed limit when i choose it to be on the displayed info screen. thanks anyways.! Quote Link to post Share on other sites
Bumble Bee Posted May 13, 2009 Report Share Posted May 13, 2009 seems to be working fine, but it doesnt seem to show speed limit when i choose it to be on the displayed info screen. thanks anyways.! I think the Acura doesn't have VSS it has canbus you need to reverse that ... Quote Link to post Share on other sites
