mythek88 Posted June 9, 2009 Report Share Posted June 9, 2009 Hello, Info: I have an AVIC-F90BT headunit (w/ version 2.0 update preinstalled) installed with hardwire bypass. Phones that I've tried to pair with the system are: SONY ERICSSON W810i and BLACKBERRY CURVE 8900. I've tried both bluetooth update versions 3.3 and other 2.9 (the version for w300i or sumthing) Both ringtone and voice volume settings are turned up. Speakers are powered by an aftermarket amplifier I can hear music/movie/navigation sounds just fine Problem: I was able to connect both phones to the headunit. Connection was successfully established; phone was sucessfully sync'ed to the headunit; once call was connected, the other end could hear me just fine. Only problem is that I could NOT hear the other person through my speakers. Does anyone have any idea? Thanks in advance for any inputs, Gullit Quote Link to post Share on other sites
j1balogh Posted June 11, 2009 Report Share Posted June 11, 2009 I have the same issue, Blackberry pearl syncs fine, contacts, dials, connects then no sound. One time I heard something for about 100mS then nothing. Quote Link to post Share on other sites
mythek88 Posted June 12, 2009 Author Report Share Posted June 12, 2009 still no luck anyone? Quote Link to post Share on other sites
minifreezer Posted June 16, 2009 Report Share Posted June 16, 2009 This may sound stupid, but my phone has been fine with this unit since the day i bought it. One day i had the same prob, make a call and the other end could hear me but i could not hear them. Play ed with setting and then realized that my phone was on mute. Unmuted the phone and thing started working, so i got curious about the volume. If i adjust the volume on the phone it affects the volume on the unit during phone calls. Turn the volume up on the phone during a call and volume increase through the system. Not saying this is you r prob but it does not hurt to check it out. Hope you get it fixed Quote Link to post Share on other sites
CraigZ77 Posted June 20, 2009 Report Share Posted June 20, 2009 My unit does the same exact thing. the only difference is that the navigation voice cuts out also. everything else works great. Any ideas anyone? Quote Link to post Share on other sites
J-Bone Posted June 20, 2009 Report Share Posted June 20, 2009 Hello, Info: I have an AVIC-F90BT headunit (w/ version 2.0 update preinstalled) installed with hardwire bypass. Phones that I've tried to pair with the system are: SONY ERICSSON W810i and BLACKBERRY CURVE 8900. I've tried both bluetooth update versions 3.3 and other 2.9 (the version for w300i or sumthing) Both ringtone and voice volume settings are turned up. Speakers are powered by an aftermarket amplifier I can hear music/movie/navigation sounds just fine Problem: I was able to connect both phones to the headunit. Connection was successfully established; phone was sucessfully sync'ed to the headunit; once call was connected, the other end could hear me just fine. Only problem is that I could NOT hear the other person through my speakers. Can you hear the Navigation Voice? ie. right turn ahead... If you can't then it is possible that only the rear RCA's are connected to the amplifier. The navi voice and your caller's voice only come out of the front outputs. It's stupid, but this happens a lot. Does anyone have any idea? Thanks in advance for any inputs, Gullit Quote Link to post Share on other sites
mythek88 Posted June 21, 2009 Author Report Share Posted June 21, 2009 yeaa navigation voice works, music from CD works, music from radio works, music from usb works, every sound works except for the bluetooth sound Quote Link to post Share on other sites
tom.rune Posted June 26, 2009 Report Share Posted June 26, 2009 I have the exact same issue. Have anyone tried if it is the same problem as described in this post? viewtopic.php?f=33&t=21337&p=143673&hilit=+iphone+bluetooth#p143673 Quote Link to post Share on other sites
