mcbride_c Posted June 21, 2009 Report Share Posted June 21, 2009 I upgraded from a Avic-d1 to a Avic-Z2 about 2 weeks ago. So far I have done the bypass update and the gracenotes update. However EVERY time I try to do the pioneer firmware update it goes through the process, gets to the "This Program Is Being Updated...". Then it Fails and reboots and tries again. I let it try multiple times and still the same result. I left the disc in overnight and tried let it try again in the morning and same result. I burned new discs 3 times with windows burning program and Nero. Same result. Any idea on what I could be doing wrong? Thanks Quote Link to post Share on other sites
jwq Posted June 21, 2009 Report Share Posted June 21, 2009 ????? How can you update from a D1 to a Z3 ? They are incompatible units ?... Quote Link to post Share on other sites
mcbride_c Posted June 21, 2009 Author Report Share Posted June 21, 2009 Meaning I had a D1. And now purchased a Z-2. A bit too literal. Quote Link to post Share on other sites
jwq Posted June 21, 2009 Report Share Posted June 21, 2009 Meaning I had a D1. And now purchased a Z-2. A bit too literal. OK, my mistake I was wondering.... Quote Link to post Share on other sites
fresh Posted June 23, 2009 Report Share Posted June 23, 2009 im hvaing the same problem with my z2 ive burned with nero and windows burning mutliple times. it just says cd inserted.. some help me please? Quote Link to post Share on other sites
bridge4d Posted June 23, 2009 Report Share Posted June 23, 2009 If memory serves, you just have to keep rebooting. You should notice that the % complete bar still keeps counting up even though it says it fails. I recall going through this with mine and it took some time as well was very frustrating. Another option is to purchase an already updated hard drive from a certain member here that sells them... Quote Link to post Share on other sites
fresh Posted June 24, 2009 Report Share Posted June 24, 2009 thanks for the reply. But mine wont even attempt to load or install. it just say cd inserted... doesnt do anyhting. Quote Link to post Share on other sites
bridge4d Posted June 24, 2009 Report Share Posted June 24, 2009 What program are you using to burn the CD? Nevermind, I see you're using Nero. What brand of CD? I've heard that some types don't work so well. I use standard CD-R's from Office Depot. Never have an issue. There are also other "rules" for buring CDs mentioned in the manual. Quote Link to post Share on other sites
bridge4d Posted June 24, 2009 Report Share Posted June 24, 2009 Check your settings in Nero to conform to the following: â’ You can only use a CD-R (-RW) finalized with single-session. â’ You can only use a CD-R (-RW) finalized with “Mode1â€. Quote Link to post Share on other sites
fresh Posted June 24, 2009 Report Share Posted June 24, 2009 i followed those rules. Burned as DATA by the way Quote Link to post Share on other sites
