lordvdr Posted July 8, 2009 Report Share Posted July 8, 2009 Hello, I tried loading this firmware update this morning and everything was going just fine until I received the following error: Search Error: Storage Card\LPUE080\APL3\*.* I checked the original zip file I downloaded from Pioneer and there was no APL3 subdirectory in LPUE080. I even tried redownloading the zip file, only to get the same results. Pioneer is telling me now that I have to send my 900BT in to have it reloaded. Has anybody else had this problem? Quote Link to post Share on other sites
oren Posted July 8, 2009 Report Share Posted July 8, 2009 APL3 directory must be on the update, try to create manualy on the SD , and update again. Quote Link to post Share on other sites
lordvdr Posted July 8, 2009 Author Report Share Posted July 8, 2009 I just did that, after re-downloading the zip file from the Pioneer website and reformatting the SD card and I got the same result. I guess I'll try getting the SD card from Pioneer?? Quote Link to post Share on other sites
lordvdr Posted July 8, 2009 Author Report Share Posted July 8, 2009 OK, so I'm a total idiot. I totally spaced on the part where you very clearly said try to manually create the APL3 subdirectory and update again. When I manually put the APL3 subdirectory on the SD card, the update completed successfully Thanks! Quote Link to post Share on other sites
pablo494 Posted September 6, 2009 Report Share Posted September 6, 2009 hi I am having a problem finding the APL3 file to complete my update to 200.6 Quote Link to post Share on other sites
drewabbey Posted October 1, 2009 Report Share Posted October 1, 2009 when i try to do the update, my f90bt does not automatically update...I've reformatted the card to fat32 and the only things on the SD card are the lp... and the tts folders...should I extract the data out of those folders on the the base folder of the SD card? Quote Link to post Share on other sites
laci102 Posted October 4, 2009 Report Share Posted October 4, 2009 Please help: I have a AVIC F900 BT type of device, it Version 2.5. I would like to update the map but can not see the machine in the corresponding fresh map. What can be done to work? Quote Link to post Share on other sites
