higherlevel28 Posted August 1, 2009 Report Share Posted August 1, 2009 any1 can tell me why i cant hear any1 when i try makein a call after i bluetooth it to my F series radio? the call went thru but cant hear the person....thank in advance... Quote Link to post Share on other sites
tail24 Posted August 2, 2009 Report Share Posted August 2, 2009 Is it synched correctly? Did you turn the phone convo volume up?? Quote Link to post Share on other sites
higherlevel28 Posted August 3, 2009 Author Report Share Posted August 3, 2009 yes, i did turn the phone convo upon the phone Quote Link to post Share on other sites
avic_weo Posted August 4, 2009 Report Share Posted August 4, 2009 use the other BT firmware level than the one you are using right now. Weo Quote Link to post Share on other sites
higherlevel28 Posted August 4, 2009 Author Report Share Posted August 4, 2009 hey weo, whats BT firmware? thanks in advance for your help... Quote Link to post Share on other sites
tail24 Posted August 4, 2009 Report Share Posted August 4, 2009 go on pioneers website and search F series BT update/upgrade Quote Link to post Share on other sites
avic_weo Posted August 5, 2009 Report Share Posted August 5, 2009 BT = BlueTooth bear in mind that by "other" I mean "not the one you are using right now". Basically if you have 3.3, you should go to 2.9, and vice versa... Weo Quote Link to post Share on other sites
higherlevel28 Posted August 16, 2009 Author Report Share Posted August 16, 2009 good day, i change my blue tooth from 3.3 to 2.9 as reccomended but still yet am havein problem, when i make a call on my unit F900 the person can hear me but i still cant hear them and my mic is connected, any1 can help? Quote Link to post Share on other sites
dhp106 Posted August 18, 2009 Report Share Posted August 18, 2009 my guess would be bad wiring. check the harness? Quote Link to post Share on other sites
higherlevel28 Posted October 10, 2009 Author Report Share Posted October 10, 2009 good day all, form i bought my f900 unit am having problem make call on it, bt connect well, ph book copied but when its time to make or receive calls i cant hear nothing the unit just go in silent mood, i update the bt its the same thing, check connections everything connect properly. can any1 asset me??? Quote Link to post Share on other sites
