FirePhoenox Posted August 15, 2009 Report Share Posted August 15, 2009 I know it has been asked before but after looking over the forums for 3 days its time to ask. in the new 3.0 does anyone know how to change the "TOP MENU" Background image? i was told it was file 746_32K_MN-000_24b.bmp in the image.res, but there is no file by that name so i decided to make one and it does not work. anyone have any idea's? Quote Link to post Share on other sites
touche6784 Posted August 15, 2009 Report Share Posted August 15, 2009 I have been trying to find this out as well but no luck. It seems like the units are no longer utilizing that file for a background on the top menu. If I add a file with that name I get a background in the navi related menus. Quote Link to post Share on other sites
FirePhoenox Posted August 15, 2009 Author Report Share Posted August 15, 2009 yep, i changed the Navi menus to my background but thats in the Data.zip filein the folder APL2, everything in there is Map related. the Top menu background is in the Image.Res file in the APL Folder, well it was before all the updates Quote Link to post Share on other sites
eurotuner29 Posted August 15, 2009 Report Share Posted August 15, 2009 yep, i changed the Navi menus to my background but thats in the Data.zip filein the folder APL, everything in there is Map related. the Top menu background is in the Image.Res file in the APL2 Folder, well it was before all the updates Can we some pics of what you have done so far? Quote Link to post Share on other sites
touche6784 Posted August 15, 2009 Report Share Posted August 15, 2009 yep, i changed the Navi menus to my background but thats in the Data.zip filein the folder APL, everything in there is Map related. the Top menu background is in the Image.Res file in the APL2 Folder, well it was before all the updates i added the said .bmp file to the Image.Res file and the pic ended up being a background for the navi menus. Pioneer may have just coded out the usage of a background on the Top Menu. Quote Link to post Share on other sites
MilesA Posted August 16, 2009 Report Share Posted August 16, 2009 I just customized my Top Menu and it is the exact same in version 3 as it was in version 2. The Image.res file you are looking for is in the APL folder, not the APL2 folder. A previous post had them backwards which may be why you're having trouble. cheers Quote Link to post Share on other sites
jenger2000 Posted August 16, 2009 Report Share Posted August 16, 2009 What is the file name that we need to change? Quote Link to post Share on other sites
MilesA Posted August 16, 2009 Report Share Posted August 16, 2009 Try this thread... http://www.avic411.com/forum/viewtopic.php?f=34&t=21840 Quote Link to post Share on other sites
touche6784 Posted August 16, 2009 Report Share Posted August 16, 2009 Try this thread... http://www.avic411.com/forum/viewtopic.php?f=34&t=21840 I tried that thread and could not find anything. Maybe I overlooked something. I found the Image.Res file in the common folder and added the file with that name and got the results that I had said. Dunno if I did anything wrong. Quote Link to post Share on other sites
touche6784 Posted August 16, 2009 Report Share Posted August 16, 2009 This is what I got when I tried adding the file to the common folder in the Image.Res file. This is obviously not the actual unit but it is pretty close. I am using the emulator to get the mainmenu.exe to run and show what comes up. I added the pic which was a 24 bit .bmp file to the common folder using 7zip without unpacking Image.Res. I got stuck here and gave up. Quote Link to post Share on other sites
FirePhoenox Posted August 16, 2009 Author Report Share Posted August 16, 2009 This is what I got when I tried adding the file to the common folder in the Image.Res file.[attachment=0]top menu.jpg[/attachment] This is obviously not the actual unit but it is pretty close. I am using the emulator to get the mainmenu.exe to run and show what comes up. I added the pic which was a 24 bit .bmp file to the common folder using 7zip without unpacking Image.Res. I got stuck here and gave up. Thats Black background with no icons touche6784 is becaause you Zipped it wrong, after you un zip the Image.res and add the .bmp you need to go into the first image folder and zip that back up not the main folder that it unzipped Quote Link to post Share on other sites
FirePhoenox Posted August 16, 2009 Author Report Share Posted August 16, 2009 What is the file name that we need to change? i was told it was file 746_32K_MN-000_24b.bmp in the image.res, but there is no file by that name so i decided to make one and it does not work. anyone have any idea's? Quote Link to post Share on other sites
FirePhoenox Posted August 16, 2009 Author Report Share Posted August 16, 2009 Can we some pics of what you have done so far? I will get some pics on here maybe tonight or early tomorrow. looking for my camra cord atm lol Quote Link to post Share on other sites
MilesA Posted August 16, 2009 Report Share Posted August 16, 2009 This is what I got when I tried adding the file to the common folder in the Image.Res file.[attachment=0]top menu.jpg[/attachment] This is obviously not the actual unit but it is pretty close. I am using the emulator to get the mainmenu.exe to run and show what comes up. I added the pic which was a 24 bit .bmp file to the common folder using 7zip without unpacking Image.Res. I got stuck here and gave up. Are you trying to change the actual black background or the three images for the destination, contacts, and AV source buttons? Quote Link to post Share on other sites
FirePhoenox Posted August 16, 2009 Author Report Share Posted August 16, 2009 Are you trying to change the actual black background or the three images for the destination, contacts, and AV source buttons? The Actual Black Background Quote Link to post Share on other sites
