warchild119 Posted August 25, 2009 Report Share Posted August 25, 2009 i have a z2 installed with the wire by pass but now i bought a new hard drive with the updated maps and i'm not sure if by installing this new drive will have any effect on the bypass. can anyone help me with this confusion? Quote Link to post Share on other sites
garrettoomey Posted August 25, 2009 Report Share Posted August 25, 2009 If you have the 2 wire bypass, your upgraded drive should work fine. If you got the drive from me, then I KNOW it will work fine with the 2 wire bypass. Quote Link to post Share on other sites
Nutty Professor Posted September 5, 2009 Report Share Posted September 5, 2009 If you have the 2 wire bypass, your upgraded drive should work fine. If you got the drive from me, then I KNOW it will work fine with the 2 wire bypass. Will the bypass work with a factory/locked drive? I have a Z2 (with the original hard drive) that I'm about to install in my car. I performed the two wire bypass. Do I need to upgrade to an unlocked drive for the bypass to work? Quote Link to post Share on other sites
garrettoomey Posted September 5, 2009 Report Share Posted September 5, 2009 If you have the 2 wire bypass, your upgraded drive should work fine. If you got the drive from me, then I KNOW it will work fine with the 2 wire bypass. Will the bypass work with a factory/locked drive? I have a Z2 (with the original hard drive) that I'm about to install in my car. I performed the two wire bypass. Do I need to upgrade to an unlocked drive for the bypass to work? Nope. Quote Link to post Share on other sites
Nutty Professor Posted September 5, 2009 Report Share Posted September 5, 2009 If you have the 2 wire bypass, your upgraded drive should work fine. If you got the drive from me, then I KNOW it will work fine with the 2 wire bypass. Will the bypass work with a factory/locked drive? I have a Z2 (with the original hard drive) that I'm about to install in my car. I performed the two wire bypass. Do I need to upgrade to an unlocked drive for the bypass to work? Nope. Thanks Garret. I'm glad it will work. Quote Link to post Share on other sites
rybob1 Posted October 27, 2009 Report Share Posted October 27, 2009 Anyone have a good reference to do the bypass? I have garret's drive, but still get the warnings and the eventual blocking of the dvd playback, when I notch up the e-brake one notch while driving. Quote Link to post Share on other sites
garrettoomey Posted October 27, 2009 Report Share Posted October 27, 2009 See this post: viewtopic.php?f=20&t=24033 If the bypass is done correctly, it WILL work. Quote Link to post Share on other sites
