SWEETNSLOWPOPS Posted September 6, 2009 Report Share Posted September 6, 2009 Hey Guys. I just installed the AVIC z110BT and I am having a issue. The bybass worked and I am able to use the video while driving but I get an error message no matter what I am doing on the unit about every 2 minutes. It says something about a system reset due to tuner error....? I have no clue. Also, the product key won't come up for my MSN direct tuner but everything is installed according to the installation manual. Any suggestions or ideas?? I was going to reset the system but I couldn't find where to do that (Didn't really look yet either) ANY help would be greatly appreciated! Thanks Quote Link to post Share on other sites
Nerds 2 You Posted September 15, 2009 Report Share Posted September 15, 2009 Pg 175 in the novel about the spanish guy that came with the unit (Manual) There are 4 methods you can use to do the reset, you should start with method 2 and go from there. Method 2: Touch [Restore Factory Settings] This clears some items in the “Navi Settings” menu, the “System Settings” menu and the “Bluetooth Settings” menu. Did you actually purchase and install an MSN tuner? It isn't built in to the unit. Quote Link to post Share on other sites
VBLUE42 Posted September 16, 2009 Report Share Posted September 16, 2009 Did you actually purchase and install an MSN tuner? It isn't built in to the unit. Not with the Z110. It is a separate tuner. Quote Link to post Share on other sites
Nerds 2 You Posted September 16, 2009 Report Share Posted September 16, 2009 Right, it ISN'T built in to the unit. Quote Link to post Share on other sites
