diaftia Posted September 8, 2009 Report Share Posted September 8, 2009 I am racking my brain here. I am using Photoshop CS3 and its a tool that I have not exactly mastered. I have searched and all I have found is that I need to use an alpha mask. Problem is more searching doesnt seem to lead me to a way to do this. I have a new layer, I have moved it down below my existing one, and I either get a white background or no image at all. I need to make the background of my image transparent. What is the best way to go about doing this in PS-CS3? If I open the file back up after saving it should show up with a checkerboard background correct? Thanks, Alex Quote Link to post Share on other sites
ill.die.trying Posted September 8, 2009 Report Share Posted September 8, 2009 I am racking my brain here. I am using Photoshop CS3 and its a tool that I have not exactly mastered. I have searched and all I have found is that I need to use an alpha mask. Problem is more searching doesnt seem to lead me to a way to do this. I have a new layer, I have moved it down below my existing one, and I either get a white background or no image at all. I need to make the background of my image transparent. What is the best way to go about doing this in PS-CS3? If I open the file back up after saving it should show up with a checkerboard background correct? Thanks, Alex if the file has a checked background it would show as black or white or may not even show on screen, the best way is to have that checkered part masked Quote Link to post Share on other sites
MikeTheApeman Posted September 8, 2009 Report Share Posted September 8, 2009 To make a transparent bitmap you must make sure that the bitmap has been converted to Indexed 256 colour. 24bit Bitmaps will not make a transparent image. Make sure that pixel (0,0) in the top left most part of thepicture has the colour you want to be transparent. If you have a background colour that you do not want to be transparent put another colour at pixel (0,0), preferably 1 that doesn't appear in the rest of the image. Someimage allow you to add a colour to the palette if needed. In some cases setting colour 0 in the colour index also can help. Quote Link to post Share on other sites
diaftia Posted September 8, 2009 Author Report Share Posted September 8, 2009 To make a transparent bitmap you must make sure that the bitmap has been converted to Indexed 256 colour. 24bit Bitmaps will not make a transparent image. Make sure that pixel (0,0) in the top left most part of thepicture has the colour you want to be transparent. If you have a background colour that you do not want to be transparent put another colour at pixel (0,0), preferably 1 that doesn't appear in the rest of the image. Someimage allow you to add a colour to the palette if needed. In some cases setting colour 0 in the colour index also can help. Wow, I need to take a photoshop class apparently as this is all a foreign language to me. When I go to image/mode indexed color is grayed out. And when I try to go new image, bitmap it wont let me create a transparent background. I guess this is just going to require a lot of back and fourth trial and error. Quote Link to post Share on other sites
diaftia Posted September 8, 2009 Author Report Share Posted September 8, 2009 Ah! I got it! I had to create the image with a transparent background. Then convert the main layer to a background layer. Once I did that I went into the channels tab and created a new channel as an Alpha layer. They key was to do the edits I needed on that layer which then started to show in the avic. Quote Link to post Share on other sites
