mrchrisalba Posted September 27, 2009 Report Share Posted September 27, 2009 So I am hoping there is a way to fix this problem. I have a power antenna and it will go up when I select AM or FM but when I select HD Radio, it won't go up. I know I can set it to just always be up but I don't want it to always be up. Any help would be appreciated. Thanks Quote Link to post Share on other sites
bloodninja Posted September 27, 2009 Report Share Posted September 27, 2009 Dunno.. I was about to type "just set it to be up when the unit is powered on in the settings menu", but then I read that you don't wanna do that. So I dunno. Quote Link to post Share on other sites
mrchrisalba Posted September 28, 2009 Author Report Share Posted September 28, 2009 Nevermind, I just took my power antenna out and put a regular one on. Quote Link to post Share on other sites
1loudls Posted September 30, 2009 Report Share Posted September 30, 2009 yea the power antenna wire can only be set to radio (where it turns the antenna wire on only when the internal radio is the active source) or power (where the antenna wire is turned on all the time when the AVIC is powered on ) it seem that they should have thought about this for the HDradio tuners, just another reason that the external HD radio modules are not thought out fully and dont work as well as internal HD radios. Quote Link to post Share on other sites
