VBLUE42 Posted November 19, 2009 Report Share Posted November 19, 2009 Go into the NAVI SETTINGS screen and verify the PARKING BRAKE is ON. If it is then that part is grounded properly. The problem at that point will certainly be the relocated wire. Quote Link to post Share on other sites
sotorious Posted November 19, 2009 Author Report Share Posted November 19, 2009 ok so all and all that is not suppose to happen correct. Quote Link to post Share on other sites
VBLUE42 Posted November 19, 2009 Report Share Posted November 19, 2009 If the p brake wire is grounded properly it will say ON. So that part is grounded correctly. That would indicate the problem is with the relocated wire. Quote Link to post Share on other sites
VBLUE42 Posted November 19, 2009 Report Share Posted November 19, 2009 ok so all and all that is not suppose to happen correct. No, if the bypass is done correctly. Quote Link to post Share on other sites
sotorious Posted November 19, 2009 Author Report Share Posted November 19, 2009 Well i checked and it said parking break on, while im driving and im in the system settings ill see the icons get grayed out and come back, so it must be a loose wire or something, i might pull it off tonight and recheck it.. so you think its that yellow wire that i had to move 1 over??? what if i pull it off and it seems to be stably set. then what? Quote Link to post Share on other sites
VBLUE42 Posted November 20, 2009 Report Share Posted November 20, 2009 Why don't you just recheck your install like I have suggested here many times now before you start trying to concern yourself with a "then what" situation. The problem is with one of those two wires, period. Fix it and the problem will go away. Quote Link to post Share on other sites
sotorious Posted November 21, 2009 Author Report Share Posted November 21, 2009 yea i need to get time to rip everything out. Quote Link to post Share on other sites
Join the conversation
