torres1708 Posted January 12, 2010 Report Share Posted January 12, 2010 So here's the deal... I have two F500BT units. I recently bought the CNSD-150FM for the firmware and map update. I ran it on my first unit and everything worked just fine.... Now, on the second unit, I installed the first SD card and it worked fine, but when I got to the second SD card, it kept asking for a password and I soon found out that you can only use the SD cards on one unit... My question is, is there any way to update my second unit? Could I dump the files straight off the second SD card onto the 2nd unit without a problem? Is there anything else I can do to make this work? I bought the SD card and I really don't want to buy another set just for a password. I really don't like the fact that PIONEER set things up this way... Any help would be appreciated. Quote Link to post Share on other sites
ndy4eva Posted January 12, 2010 Report Share Posted January 12, 2010 I don't think it's possible. I believe the second SD card contains the new iGO app (v8.3) and new maps. They require new license to run. However, if you don't mind running "hacked" version of iGO, you could run iGO app & map from "x910bt dump" available in this forum. Please read following threads. viewtopic.php?f=34&t=25838&start=45#p184341 viewtopic.php?f=34&t=25751&start=585#p203900 Quote Link to post Share on other sites
torres1708 Posted January 12, 2010 Author Report Share Posted January 12, 2010 How could I go about doing that? Quote Link to post Share on other sites
ndy4eva Posted January 12, 2010 Report Share Posted January 12, 2010 The linked threads have all the details how to upgrade iGO app & map. Quote Link to post Share on other sites
torres1708 Posted January 13, 2010 Author Report Share Posted January 13, 2010 I looked at those, but the links to the downloads don't work... that's why I wanted to see if I can use the files I have on the SD cards. Quote Link to post Share on other sites
ndy4eva Posted January 13, 2010 Report Share Posted January 13, 2010 MyITGuy posted another package at megaupload. http://www.megaupload.com/?d=K0WJSCUR http://www.megaupload.com/?d=XDPTH67G Last time I checked, it's still working. Quote Link to post Share on other sites
torres1708 Posted January 13, 2010 Author Report Share Posted January 13, 2010 Thanks... Quote Link to post Share on other sites
ndy4eva Posted January 15, 2010 Report Share Posted January 15, 2010 torres1708, Did you get my PM? Could I get a copy of first SD card (firmware)? Quote Link to post Share on other sites
lupanare Posted January 16, 2010 Report Share Posted January 16, 2010 Excuse me but this version is good for european Avic? Thanks Quote Link to post Share on other sites
Klownicle Posted January 23, 2010 Report Share Posted January 23, 2010 Those links don't look like they are the "CNSD-150FM" which is for the F500BT becuase the Sys.Txt is not the F500BT unit info? Quote Link to post Share on other sites
