catdaddy Posted December 5, 2006 Report Share Posted December 5, 2006 I'm having issues with the sound from my Z1. My car is a SRT8 with the oem kicker system. I'm trying to use (3) PAC modules, C2R-CHY,SWI-CAN,SWI-PS and the sound was muffled when I used the rear speaker leads for sound, then I read that I should use the front speaker leads, switched them over and now I have no sound. can anyone give me the correct wiring setup ??????? Quote Link to post Share on other sites
cntrylvr79 Posted December 5, 2006 Report Share Posted December 5, 2006 From what I've read about the pac interface it's meant to integrate the boston acoustic system, not the kicker system. So that right there might be your problem. Have you tried asking this question on www.chargerforums.com Quote Link to post Share on other sites
catdaddy Posted December 6, 2006 Author Report Share Posted December 6, 2006 I found the problem with a little help from a 411 member. I had overlooked the blue/white wire because it was on the plug with some RCA inputs and I wasn't planning on using those. also the PAC interface works fine with the kicker amp. Quote Link to post Share on other sites
cntrylvr79 Posted December 7, 2006 Report Share Posted December 7, 2006 I found the problem with a little help from a 411 member. I had overlooked the blue/white wire because it was on the plug with some RCA inputs and I wasn't planning on using those. also the PAC interface works fine with the kicker amp. cool glad it worked out for you. And looky I learned something new today. The pac interface works with the kicker bits. Quote Link to post Share on other sites
