Bento Posted April 16, 2010 Report Share Posted April 16, 2010 Does anyone know how to change the beeping distance for speedcams on the F900? It drives me nuts because it starts beeping way before it needs to beep, especially on the smaller roads. I don't know what the current distance is (European model, Kilometers) but i want it to beep like 300 or 500 meters in advance. Please help! Rgrds, Bento Quote Link to post Share on other sites
BorisM Posted April 16, 2010 Report Share Posted April 16, 2010 Does anyone know how to change the beeping distance for speedcams on the F900? It drives me nuts because it starts beeping way before it needs to beep, especially on the smaller roads. I don't know what the current distance is (European model, Kilometers) but i want it to beep like 300 or 500 meters in advance. Please help! Rgrds, Bento In SYS.TXT you coulkd try adding/testing these entries in the [warning] section: approach_beep_distances="8,16,24" ;("8,16,24") warn_distances="120:600,100:400,80:300,50:100" ;("110:1000,80:800,60:500,40:300") speed:distance Second one is probably better because it defines a curve that warns you earlier when you drive faster, and later when you drive slower. Quote Link to post Share on other sites
Bento Posted April 17, 2010 Author Report Share Posted April 17, 2010 Thanks Does this involve going into testmode? (never done that). Or can i change a file in the firmware and then flash the unit? Are these KM's, miles, feet? Oh and what does the first one do (strange units, 8 feet?) (approach_beep_distances="8,16,24" ;("8,16,24")? I don't mind the unit warning me for speedcams at a fixed distance if that is possible. Quote Link to post Share on other sites
BorisM Posted April 19, 2010 Report Share Posted April 19, 2010 Thanks Does this involve going into testmode? (never done that). Or can i change a file in the firmware and then flash the unit? Are these KM's, miles, feet? Oh and what does the first one do (strange units, 8 feet?) (approach_beep_distances="8,16,24" ;("8,16,24")? I don't mind the unit warning me for speedcams at a fixed distance if that is possible. You'll need to get into testmode. Firmware updates do not work with modified files. The first one... probably some internal measures NNG uses. On the second one, I'd think it would be Km/h:meters from the look of it. Also, some of the mods you could install let you specify a hardwired warning distance. Quote Link to post Share on other sites
Bento Posted August 22, 2010 Author Report Share Posted August 22, 2010 I went into testmode but the sys.txt hardly contains any information. No speedcam info whatsoever. Quote Link to post Share on other sites
BorisM Posted August 23, 2010 Report Share Posted August 23, 2010 I went into testmode but the sys.txt hardly contains any information. No speedcam info whatsoever. If they aren't there, iGO is using internal defaults. Just add the appropriate data to the file. Quote Link to post Share on other sites
Bento Posted August 23, 2010 Author Report Share Posted August 23, 2010 Oh i forgot about this Yes i added them manually, haven't tested it yet. Will let u know Quote Link to post Share on other sites
