T-Shirt Posted May 18, 2010 Report Share Posted May 18, 2010 All: I have upgraded to 3.02, but cannot seem to get into test mode, even with a freshly formatted SD card and the (2) test mode directories in the root--my system just boots normally. Am I missing something here? Any help would be appreciated! Best Regards, Michael Tschirret Quote Link to post Share on other sites
FourG Posted May 18, 2010 Report Share Posted May 18, 2010 All: I have upgraded to 3.02, but cannot seem to get into test mode, even with a freshly formatted SD card and the (2) test mode directories in the root--my system just boots normally. Am I missing something here? Any help would be appreciated! Best Regards, Michael Tschirret Sadly 3.02 changed the key files required to enter test mode, so until someone like carver manages to find out what the new ones are the 3.02 and 2.08 upgraders are locked out for the time being. Quote Link to post Share on other sites
thegr8brian Posted May 18, 2010 Report Share Posted May 18, 2010 I can boot up in testmode with 3.02 just fine. Quote Link to post Share on other sites
thegr8brian Posted May 19, 2010 Report Share Posted May 19, 2010 Attached is the testmode I have been using. Just unzip and put the testmode folder on the root directory of your SD card. testmode.zip Quote Link to post Share on other sites
T-Shirt Posted May 19, 2010 Author Report Share Posted May 19, 2010 Thank you very much; I really appreciate it! One question: the extracted file has only one folder ("testmode") which I have put on the root of the SD card. Previously, there was a second folder ("Mitacap") Do I need both? Or do I just extract the testmode folder to the root and let it rip? Thanks Again! Quote Link to post Share on other sites
thegr8brian Posted May 19, 2010 Report Share Posted May 19, 2010 All you need is the one testmode folder. Quote Link to post Share on other sites
mhtn Posted July 21, 2010 Report Share Posted July 21, 2010 Attached is the testmode I have been using. Just unzip and put the testmode folder on the root directory of your SD card. Would this testmode files work with f700 with firmware 2.006/2.008? I tried the ones in FAQ and they no longer work for me. Thanks. Quote Link to post Share on other sites
