steel2040 Posted June 12, 2010 Report Share Posted June 12, 2010 I have to say here is a link to a youtube video where you can kinda here the problem . I just installed the x910bt into a 2000 audi a6. I have a terriable humming noise when the rca for the speakers are pluged in I have the metra wiring harness for a factory amped bose unit . I performed a bypass and only had 5 wires i had to solder on the kit , postive,negative,memory,illumination,and amp signal wire. Quote Link to post Share on other sites
rgarjr Posted June 12, 2010 Report Share Posted June 12, 2010 well which speakers is the hum coming out of? have you tried using different RCA outputs? Using different combinations Quote Link to post Share on other sites
steel2040 Posted June 12, 2010 Author Report Share Posted June 12, 2010 Thanks for the quick reply any way ya i have tried one i have tried 4 it comes out of any one i hook an rca into and its not so much a hum but the sound of power maybe?. No clue what it is maybe i need a filter? Quote Link to post Share on other sites
steel2040 Posted June 12, 2010 Author Report Share Posted June 12, 2010 Ok I pulled the deck out 2 inches it went away now I got to figure if I need to keep all those wires extreamly far away from the deck lol Quote Link to post Share on other sites
steel2040 Posted June 13, 2010 Author Report Share Posted June 13, 2010 Pulling the deck out seemed to fix it upon closer attention going closer towards the speaker it only softend the hum/buzzing noise im still proplexed . Quote Link to post Share on other sites
sleazzy Posted May 2, 2013 Report Share Posted May 2, 2013 Sorry to bring this old thing back up.. But im having the same issuse. I have tried everyting from check RCA, Ground loop, Re-grounding.. Anyone can shine some light to this!? Quote Link to post Share on other sites
oldracer Posted May 2, 2013 Report Share Posted May 2, 2013 You might want to check the resistance on each cable between the center pin and the outer rim on each RCA plug. I am guessing one or more has bad insulation. Be sure to unplug the connector from the head unit before you test the plugs. Quote Link to post Share on other sites
