johnforeman Posted June 21, 2010 Report Share Posted June 21, 2010 Hi all, I just put my system in a few weeks ago and I'm having a strange problem. Every now and then, when the system boots up, its in full mute mode or ATT mode. As I drive for a while (10 to 15 minutes) it will start jumping in and out of att to normal sound then it will be ok. I have a 2010 camaro and I used a metra install kit which has the interface for the steering wheel controls. I also have the in motion hack. I didn't do the 'mute' pin switch as i needed that wire. I added a pin to the proper hole to do the hack. Anyone else seeing this problem? -John Quote Link to post Share on other sites
bringndefinition Posted June 24, 2010 Report Share Posted June 24, 2010 Had a similar problem in my 07 tahoe where the ATT mode would come in and out. I had the mute wire attached to the Axxess GMOS-LAN-04 LAN unit which is a plug and play harness that allows me add a after market radio and retain your accessory chimes and Onstar. The Mute ATT feature gets enabled when I start Onstar, problem is even when I am not operating Onstar the Pioneer unit would go in ATT mode. I never did figure out why it did this so as a workaround I just disconnected my mute wire and the problem disappeared. Could be a defect in the Axxess GMOS-LAN-04 LAN since it is an intermittent issue. I dont use onstar that much so I can live without Mute. Since this change the entire unit just shuts off while onstar is being used. After onstar has concluded the power is restored. Quote Link to post Share on other sites
