VBLUE42 Posted September 27, 2010 Report Share Posted September 27, 2010 If you don't have audio plugged into the 1/8" input from the Pioneer iPod cable you wont get audio. Quote Link to post Share on other sites
laracer Posted September 27, 2010 Report Share Posted September 27, 2010 If you don't have audio plugged into the 1/8" input from the Pioneer iPod cable you wont get audio. Indeed. Problem is, so far I have not had ipod audio even with the 1/8". But I will try again tonight with the disconnected antenna wire. Thanks. Quote Link to post Share on other sites
VBLUE42 Posted September 27, 2010 Report Share Posted September 27, 2010 Problem is, so far I have not had ipod audio even with the 1/8". Something else is wrong. Make sure the AV1 input is set to iPod and that the iPhone headphone output is not defective. You can even set AV1 to VIDEO and just plug the iPhone headphone output into the 1/8" AUDIO in and hit play on the iPhone just to test that it receives audio. If it doesn't you have an issue with one of the two audio connections or a bad cable. Quote Link to post Share on other sites
laracer Posted September 28, 2010 Report Share Posted September 28, 2010 Turns out that gtsdohcvvtli was correct. There was an issue with the "blue wires". After disconnecting all blue wires (i.e. my antenna stays down and there is no factory amp) I now DO have sound from my iPod (with the 1/8" cable). Yay. Thanks very much gtsdohcvvtli. I have already ordered the correct cable since I do want video support, but it's good to know there's nothing wrong with my avic. By the way, it's pretty frustrating that there are two very similar pioneer ipod cables: the CD-IU50V and the CD-IU50. Note the part numbers are identical except for the "V". Originally, I mistakenly ordered the one without the "V". Just mentioning this in the hope it prevents someone else from making the same mistake. Quote Link to post Share on other sites
24VWVR6sc Posted September 29, 2010 Report Share Posted September 29, 2010 Try unplugging your ipod from the cable and plug it back in..the sound should work. Quote Link to post Share on other sites
Join the conversation
