hondahater Posted September 29, 2010 Report Share Posted September 29, 2010 For quite a while now my MSN Direct has not worked on my F900BT. It's been a while since I actually cared also. But, I just installed the 2010 map upgrade w/the MSN Direct that has traffic. I would like to try it and see how it works. I can't do this. When I go to use it...there is ZERO signal. When I tap status it just keeps staying "Connecting to MSN Direct". Yes, I've left it on this screen for quite sometime before I gave up. The firmware update will not take place either. Lastly.....the MSN Direct Status Info screen shows no information at all!!! Please help!!!! Quote Link to post Share on other sites
BorisM Posted September 29, 2010 Report Share Posted September 29, 2010 For quite a while now my MSN Direct has not worked on my F900BT. It's been a while since I actually cared also. But, I just installed the 2010 map upgrade w/the MSN Direct that has traffic. I would like to try it and see how it works. I can't do this. When I go to use it...there is ZERO signal. When I tap status it just keeps staying "Connecting to MSN Direct". Yes, I've left it on this screen for quite sometime before I gave up. The firmware update will not take place either. Lastly.....the MSN Direct Status Info screen shows no information at all!!! Please help!!!! Hit the reset button. Quote Link to post Share on other sites
hondahater Posted September 29, 2010 Author Report Share Posted September 29, 2010 For quite a while now my MSN Direct has not worked on my F900BT. It's been a while since I actually cared also. But, I just installed the 2010 map upgrade w/the MSN Direct that has traffic. I would like to try it and see how it works. I can't do this. When I go to use it...there is ZERO signal. When I tap status it just keeps staying "Connecting to MSN Direct". Yes, I've left it on this screen for quite sometime before I gave up. The firmware update will not take place either. Lastly.....the MSN Direct Status Info screen shows no information at all!!! Please help!!!! Hit the reset button. at what point.....after it's booted up all the way?? hold it while i turn it on?? when? Quote Link to post Share on other sites
BorisM Posted September 29, 2010 Report Share Posted September 29, 2010 [quote="hondahater at what point.....after it's booted up all the way?? hold it while i turn it on?? when? The only point when it does anything -- after the unit is booted up and you have confirmed that MSN is not working (no MSN ID is displayed in the status screen). MSN receiver in this units becomes very confused if at some point it goes through an incomplete boot (i.e., you've turned the key, but then turned it back off before the unit fully booted) and does not get initialized properly. Reset usually clears it up. Quote Link to post Share on other sites
hondahater Posted September 30, 2010 Author Report Share Posted September 30, 2010 i tried the reset button after it fully booted up with no luck. also tried a factory reset with no luck. anything else?? Quote Link to post Share on other sites
BorisM Posted September 30, 2010 Report Share Posted September 30, 2010 i tried the reset button after it fully booted up with no luck. also tried a factory reset with no luck. anything else?? Strange... this tends to always work for me. Is it still showing blanks for the MSN tuner serial number? Quote Link to post Share on other sites
hondahater Posted October 1, 2010 Author Report Share Posted October 1, 2010 i tried the reset button after it fully booted up with no luck. also tried a factory reset with no luck. anything else?? Strange... this tends to always work for me. Is it still showing blanks for the MSN tuner serial number? yes same as the pics i put up in my original post Quote Link to post Share on other sites
BorisM Posted October 1, 2010 Report Share Posted October 1, 2010 yes same as the pics i put up in my original post Not sure what to do then... May be try resetting it a couple more times, and if it still does not work, call Pioneer. Quote Link to post Share on other sites
JohnnyDepp Posted October 1, 2010 Report Share Posted October 1, 2010 It won't work for ANYBODY starting in Jan 2012...lol. Perhaps it's time to switch to Kenwoods? Or hope Pioneer has a R-TDS or XM NavTraffic replacement comeing out soon to replace the MSN tuners they sold everyone?? Quote Link to post Share on other sites
hondahater Posted October 1, 2010 Author Report Share Posted October 1, 2010 It won't work for ANYBODY starting in Jan 2012...lol. Perhaps it's time to switch to Kenwoods? Or hope Pioneer has a R-TDS or XM NavTraffic replacement comeing out soon to replace the MSN tuners they sold everyone?? that's also the reason I wanted to get the msn working.....$20 for the last 15mos or so.....thats a deal to me. But I do hope that there is a replacement too....sirius traffic would be perfect to me Quote Link to post Share on other sites
