lancheon22s Posted October 16, 2010 Report Share Posted October 16, 2010 when i start the truck, it lights up, splash screen comes up, then all lights on radio turn off screen goes blank, but radio still plays??? any ideas??? before this happen i noticed my brightness was set to zero, which was odd since i have always had it set on 10 for over a year. any help please?? thanks Quote Link to post Share on other sites
w4rh4wk Posted October 20, 2010 Report Share Posted October 20, 2010 when i start the truck, it lights up, splash screen comes up, then all lights on radio turn off screen goes blank, but radio still plays??? any ideas??? before this happen i noticed my brightness was set to zero, which was odd since i have always had it set on 10 for over a year. any help please?? thanks Maybe a setting it corrupted somewhere.. I'd try reformatting the unit follow the instructions here Firmware 3.1 Warning this will delete everything off of your AVIC unit! Quote Link to post Share on other sites
johnmiller10 Posted October 28, 2010 Report Share Posted October 28, 2010 Maybe a setting it corrupted somewhere.. I'd try reformatting the unit follow the instructions here Firmware 3.1 Warning this will delete everything off of your AVIC unit! Have same issue and still goes black, any suggestions? Quote Link to post Share on other sites
lancheon22s Posted October 28, 2010 Author Report Share Posted October 28, 2010 nope, no one seems know to know the problem here. i finally was able to get into test mode and try to upgrade, and all i would get was SDMMC update failed. got no help here so i just put my factory radio back in to. good luck though Quote Link to post Share on other sites
w4rh4wk Posted October 28, 2010 Report Share Posted October 28, 2010 Have same issue and still goes black, any suggestions? What step did you get stuck on? nope, no one seems know to know the problem here. i finally was able to get into test mode and try to upgrade, and all i would get was SDMMC update failed. got no help here so i just put my factory radio back in to. good luck though If the SDMMC failed.. it can be a bunch of things... either the actual update file is corrupted.. the internal drive went bad, or it has bad blocks, bad main board. Quote Link to post Share on other sites
johnmiller10 Posted October 28, 2010 Report Share Posted October 28, 2010 What step did you get stuck on? If the SDMMC failed.. it can be a bunch of things... either the actual update file is corrupted.. the internal drive went bad, or it has bad blocks, bad main board. Im not stuck on any step. I originally had the reboot loop problem but it still played AM/FM & Sirius. After a few months, Sirius stopped working so I followed the steps in the link posted above. After copying the files over, in now displays splash screen, and goes black...no more music. Can still get into test mode. Any help would be appreciated, do not want to take apart my dash to get this out. Quote Link to post Share on other sites
LOOSEWHEEL Posted October 28, 2010 Report Share Posted October 28, 2010 Try the FX3.1 update again. Reread the thread to see the problems people have had. I found most would post a problem, then a couple posts later they resolved it as they did not follow instructions in the 1st place. Download the file again and follow instructions VERY carefully. Quote Link to post Share on other sites
johnmiller10 Posted October 29, 2010 Report Share Posted October 29, 2010 Try the FX3.1 update again. Reread the thread to see the problems people have had. I found most would post a problem, then a couple posts later they resolved it as they did not follow instructions in the 1st place. Download the file again and follow instructions VERY carefully. redid everything and now I cant get the first steps to finish b/c the system shuts down, ugh Quote Link to post Share on other sites
johnmiller10 Posted November 1, 2010 Report Share Posted November 1, 2010 Try the FX3.1 update again. Reread the thread to see the problems people have had. I found most would post a problem, then a couple posts later they resolved it as they did not follow instructions in the 1st place. Download the file again and follow instructions VERY carefully. Thanks for your reply/help, I wound up finding another post that mentioned unmounting and formating flashdisk and creating a new partition!!! Quote Link to post Share on other sites
