dto605 Posted November 1, 2010 Report Share Posted November 1, 2010 Is there anyway I can tilt the screen? I went through most option on the unit and read the manual. Thanks, Dave Quote Link to post Share on other sites
RonS Posted November 1, 2010 Report Share Posted November 1, 2010 Is there anyway I can tilt the screen? I went through most option on the unit and read the manual. Thanks, Dave Not very well. Page 14. Press the Eject button. Quote Link to post Share on other sites
dto605 Posted November 3, 2010 Author Report Share Posted November 3, 2010 Is it a permanent fix or just when you need to eject a disc? Not very well. Page 14. Press the Eject button. Quote Link to post Share on other sites
RonS Posted November 3, 2010 Report Share Posted November 3, 2010 Is it a permanent fix or just when you need to eject a disc? I don't use that feature. I gave you the page number for a reason. If you had looked you would see: "The adjusted angle of the LCD panel will bememorized and the LCD panel will automatically return to that angle the next time the LCD panel is opened or closed." Quote Link to post Share on other sites
