clbailey Posted November 30, 2010 Report Share Posted November 30, 2010 Ok I am at the OS2.0 update on my z110bt. But when I open the file for "c:uploadsCNSD-110FM-SD1" There are files labeled part1 part 2 part 3 part 4 and only part 1 will unrare with the files j:Firmware (folder) plus all the content of the folder j:Update (folder) plus all the content of the folder j:CARDINFO.cif (file) So I transfered these to the sd card and inserted after doing part one. When I try and update after about halfway it states wrong sd card please insert the correct one. What did I do wrong. Quote Link to post Share on other sites
Manifestlyrics Posted December 5, 2010 Report Share Posted December 5, 2010 Ok I am at the OS2.0 update on my z110bt. But when I open the file for "c:uploadsCNSD-110FM-SD1" There are files labeled part1 part 2 part 3 part 4 and only part 1 will unrare with the files j:Firmware (folder) plus all the content of the folder j:Update (folder) plus all the content of the folder j:CARDINFO.cif (file) So I transfered these to the sd card and inserted after doing part one. When I try and update after about halfway it states wrong sd card please insert the correct one. What did I do wrong. Did you ever figure out how to solve this problem I am stuck !?!? Please if yo have any information Email me or respond Manifestlyrics@yahoo.com Quote Link to post Share on other sites
felixgun Posted January 13, 2011 Report Share Posted January 13, 2011 Did you try to re-format the SD card (FAT32 remember...) again and re-copy the extracted files? The Firmware and Update folder and cardinfo.cif file are the only three things that are supposed to be on the root folder of your SD card drive. Quote Link to post Share on other sites
