mike cartagena Posted December 6, 2010 Report Share Posted December 6, 2010 I have a jailbroken Iphone 4 . I installed landscape TVOut. The video will only play when I set AV1 to video. If I set it to ipod it will not work. AV2 will not work display video even when I set it to video. Is this an installation issue or configuration issue? If I set AV1 to video my pandora will not work. How can I get the video to work on AV2 so that pandora and video from my Iphone will work? Thanks. Quote Link to post Share on other sites
VBLUE42 Posted December 7, 2010 Report Share Posted December 7, 2010 First of all what app are you trying to play video from on AV1? And AV2 will do you no good unless the phone is plugged into that input. Quote Link to post Share on other sites
mike cartagena Posted December 15, 2010 Author Report Share Posted December 15, 2010 I am trying to play my videos from my iphone. The videos you create with your iphone. My iphone is pluged in by with the Pioneer CD-IU50V. Quote Link to post Share on other sites
VBLUE42 Posted December 15, 2010 Report Share Posted December 15, 2010 On the ipod source on the unit select VIDEO, choose a video and when it starts playing open the photos app on the phone and select your video. It will then be displayed on the screen of the unit. Quote Link to post Share on other sites
mike cartagena Posted December 15, 2010 Author Report Share Posted December 15, 2010 If I select video on the AV1, then Pandora will not work. Pandora will only work if AV1 is selected to ipod. AV2 is selected to video but the iphone video will not play from AV2 (unlike when I set AV1 to video). Is this an installation issue or unit configuration issue? Quote Link to post Share on other sites
RonS Posted December 15, 2010 Report Share Posted December 15, 2010 If I select video on the AV1, then Pandora will not work. Pandora will only work if AV1 is selected to ipod. AV2 is selected to video but the iphone video will not play from AV2 (unlike when I set AV1 to video). Is this an installation issue or unit configuration issue? Mike, Yes, the configuration needs to be changed when you switch between playing iPod videos and the Pandora app. But really, how often are you playing videos from your iPod? I haven't even bothered trying. Honestly, if I was really going to play videos in my 987 (which I'm not), I'd play from SD or DVD. I'd think you'd be too busy in your 911 too BTW, I think - but am not sure - it is possible change from iPod to AV1 on the scrolling source wheel on the left side of the Z120 screen, so you might not have to go into the settings to reconfigure. I notices one of the icons is a toggle. Pressing it went between ipod, AV1, AV2. I couldn't think of any use for this feature at the time. But it might come in handy for this. Give it a try. Quote Link to post Share on other sites
VBLUE42 Posted December 16, 2010 Report Share Posted December 16, 2010 Is this an installation issue or unit configuration issue? The problem you are having is user error, not a unit issue. Set the AV1 input to iPod and leave it that way. All videos, music, Pandora and any other AV app will work from that input. You should not even be using AV2 with the iPod. Its a completely separate input and should not even be used with the iPod if you have the ipod cable. Quote Link to post Share on other sites
