Number1Guru Posted December 10, 2010 Report Share Posted December 10, 2010 I love Abb's Themes I have the A/V Changed to Blue Chrome. Can someone Help me using Abb's NAV Mod V4.0 'All-in-One' -- Oct 24th '10 I want all the Chrome Grey to be Chrome Blue in the NAV area only meaning the data.zip file. I played with it alot but some reason I can only open maybe 30 files out of the 824 in the ui_pioneer\800_480 folder Quote Link to post Share on other sites
abb1 Posted December 10, 2010 Report Share Posted December 10, 2010 It is easy! Just use 'selective color' to change it to the color that you want and then perform it as an action. Next just use that action on all images that younwant to change and they will all be the same changed color Quote Link to post Share on other sites
Number1Guru Posted December 11, 2010 Author Report Share Posted December 11, 2010 It is easy! Just use 'selective color' to change it to the color that you want and then perform it as an action. Next just use that action on all images that younwant to change and they will all be the same changed color I did that on the image.res file but the data.zip Photoshop will not open all the bmp files. Only opens about 30 of the files the rest say can't open Quote Link to post Share on other sites
abb1 Posted December 11, 2010 Report Share Posted December 11, 2010 I did that on the image.res file but the data.zip Photoshop will not open all the bmp files. Only opens about 30 of the files the rest say can't open It is because they are compressed. You will need Ipaq Image Explorer 1.0.1 to open the images, save them in either 32b format or 24b format (depending if they have alpha layers) and then compress them back again after they are altered Quote Link to post Share on other sites
