cntrylvr79 Posted January 7, 2007 Report Share Posted January 7, 2007 cntrylvr79, When you posted the links to the pictures of those connectors, and asked if my factory connector looked like one or the other, were you referring to my factory stereo connectors? If so, it looks more like the 2nd gray connector, which leads me to believe that I'll have to access the wire from the PCM on the firewall under the hood. By the way, are the wires visible and accessible after I unbolt the PCM from the firewall? Thanks for letting me know the wire color. I appreciate it. If I'm not mistaken, I think it's pin 58. I'll have to look in my shop manual again. Kevin I believe the wiring can be reached without unbolting the pcm. Though doing that would give you a bit more room work. Yes the vss should be in pin 58 or 68 don't remember exactly at the moment. Quote Link to post Share on other sites
Itchy Posted January 7, 2007 Report Share Posted January 7, 2007 I recall getting the VSS from behind the gauge cluster. It's a bit more work, but was also a good opportunity to replace burned out dash bulbs. Quote Link to post Share on other sites
