avicpilot Posted February 2, 2011 Report Share Posted February 2, 2011 Any Hacks/Mods out there to make the clock bigger on the F90BT? I know the general consensus is to make it go away altogether since most newer cars have a nice digital clock already installed. But I've recently installed the F90BT into a 2002 Tahoe LT, and the only clock was on the factory head-unit. My first thought is simply replacing the Source Icon with a larger active clock... pushing the clock will still perform the source function. Anyway... anyone have any ideas for making it a bit more noticeable? Quote Link to post Share on other sites
diaftia Posted February 4, 2011 Report Share Posted February 4, 2011 You can do one of two things: 1. Open up the zip file and edit the navigatemap_800_480.ui file. Find the line for the clock and make the fontsize= value larger. 2. Check out the completed mods section and see if one of the existing mods has what you need. In my mods for example it's a little larger. What I do have though is a custom "off screen" accessible via a quick menu that would allow you to bring up a screen with a really big clock and date. If you have an MSN sub it will also show the current weather. Quote Link to post Share on other sites
trod Posted September 25, 2013 Report Share Posted September 25, 2013 will this change both the clock in the nav and a av source? Quote Link to post Share on other sites
