alfagt1963 Posted February 4, 2011 Report Share Posted February 4, 2011 Hi When using my F900BT with a route set, if the system recalculates the route it changes the map view to 'N', I have to press the map view button to return it to '2D' view. During normal use if I press the map button when the map appears it is in '2D' view and when I first set a route. Is there a setting I can change to allow the map to always default to '2D' view. Thanks Mark Quote Link to post Share on other sites
