legendarysouls Posted February 11, 2011 Report Share Posted February 11, 2011 Is there any way to wire this deck without the RCA harness ? Quote Link to post Share on other sites
JasonH Posted February 11, 2011 Report Share Posted February 11, 2011 Im not sure I understand; just don't plug it in unless you need it. Quote Link to post Share on other sites
legendarysouls Posted February 12, 2011 Author Report Share Posted February 12, 2011 i wont get any problems with Nav because tht harness has parking break and mute wire basically i got a used unit with no wires n i only got the power harness Quote Link to post Share on other sites
JasonH Posted February 13, 2011 Report Share Posted February 13, 2011 Parking break is on the power harness last time I checked. Quote Link to post Share on other sites
dianebrat Posted February 13, 2011 Report Share Posted February 13, 2011 Parking break is on the power harness last time I checked. Well the OP hasn't actually said which unit they have, but yes, ebrake is on the power harness, with no RCA harness they're SOL on the mute wire mod, but them's the breaks. Quote Link to post Share on other sites
hugosan_tr Posted February 22, 2011 Report Share Posted February 22, 2011 I didn'g get one with mine either. So i just used two pin pc soket to connect back-up camera. Without RCA it works well. Quote Link to post Share on other sites
VBLUE42 Posted February 22, 2011 Report Share Posted February 22, 2011 You can use the unit but you will not be able to do the bypass without that harness. Quote Link to post Share on other sites
