YGOSLO Posted February 14, 2011 Report Share Posted February 14, 2011 I got a lot of help from this site when I did my install last month. I figured you guys could help out with this. I'm sure it's not specific to the AVIC X920BT, but that's what I have. Stationary it sounds great. When I start driving around I get a whirring that matches engine RPM. I know the first thing everybody is going to say is "check your ground". But I found this through another forum and wondered if anyone here has any experience with it or any other ideas that may work. Check it out and let me know what you think: Ground Loop Fix Quote Link to post Share on other sites
theycallmeruffi Posted February 14, 2011 Report Share Posted February 14, 2011 i have that same problem.... Quote Link to post Share on other sites
rac4avic Posted February 20, 2011 Report Share Posted February 20, 2011 I have the same problem also. I tried the filters with the audio in and they made it worse. I tried grounding to the RCAs like in that thread and it didn't help. Let us know if you have success with anything! I got real tired of taking the stereo in and out. Quote Link to post Share on other sites
YGOSLO Posted February 22, 2011 Author Report Share Posted February 22, 2011 I have the same problem also. I tried the filters with the audio in and they made it worse. I tried grounding to the RCAs like in that thread and it didn't help. Let us know if you have success with anything! I got real tired of taking the stereo in and out. That's why I haven't touched it yet. I don't wanna pull it out and put it back in because I'll end up breaking something. Quote Link to post Share on other sites
1loudls Posted March 14, 2011 Report Share Posted March 14, 2011 well for starters, a lot more info is needed on the car and its audio system. if it is a simple audio system, which means that there is no factory or aftermarket amps other than the one that is built into the AVIC and you are having this problem, then you have a internal problem/ defective unit than needs to be repaired. if you have a factory amp, there could be a few things that are causing this problem, grounding is one of them (for best results the AVIC and the amp should share a ground point) if grounding the amp does fix this then you have a very similar problem to the issue above and you can either have it repaired or just do the band aid fix as showned. you should also be able to use a GLI (ground loop isolator) if this made it worse, then you probably have a defective GLI. GLI's them selves are another type of band aid, they might completely mask the problem or they might only help. there are too many thing that could cause ground loop interference or alternator whine, so if you dont have a lot of experience trouble shooting and fixing this problem (asking about it here, leads me to believe that you dont)you might want to =take it to a professional and have it looked at. Quote Link to post Share on other sites
