2010 map update, error message, resets to factory
I used Acronis to rewite the 2 images I needed/had to. My drive has already been unlocked from the 2008(??) map update. That partition is still defragmenting. Windows gave up on it because it has only 7% free space left and windows wants 15% free space. I have Diskeeper 2010 playing with it roght now, and as of right now its only at 34% completed. If this dosent work and I get that error message again ill make a small video for you, you seem to have your hands in about everything on here...
here is my recommendation...
1. Use acronis and create a backup of the MSV (music) and USER (personal data) partitions.
2. Use acronis to overwrite the entire drive with the 2010 Z3 image (allowing Acronis to delete all partitions).
3. Try booting to see if it works normal. This will verify the image is good.
4. Use acronis to restore your old MSV and USR partitions.
