djmixmac Posted January 13, 2007 Report Share Posted January 13, 2007 Learned much from this helpful forum. Its almost finished and is now going to be molded so the outside will be smooth black plastic. Now, I just have a question, My TSX is a NON-Navi model so in the PCM, there is a pin for the VSS Wire but no wire is present. How do I connect the VSS wire from the Z1 to this Pin? Will I have to buy some wires or can I use the existing wires from the Z1? I'm just not sure if its long enough to reach the PCM pin connectors in the footwell on the passenger side which this VSS pin is located. Quote Link to post Share on other sites
cntrylvr79 Posted January 13, 2007 Report Share Posted January 13, 2007 This is what I have listed for vss for your car. Speed Sense blue/white ECM/PCM, wht 31 pin conn E, pin 26 Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. merry xmas I think. Quote Link to post Share on other sites
